| » Oven door inner glass broken - |
Model Number: RBD305 PD89 Brand: Whirlpool Age: 5 - 10 years
New guy. Spilled liquid from roaster pan while loading pan into pre-heated upper oven. Immediately cracked the inner glass on the oven door when the liquid contacted the 400 degree surface.
Found glass part on-line but not sure if there may be further damage - other glass, gaskets to be replaced, etc. Also, I do not have a comprehensive users manual, only a "how to enjoy your double oven" new owners book. No parts list, no diagrams, etc.. Not sure how to go about taking door off. Removed 6 phillips head screws from the inner door surface facing. Inner panel does not "lift out" readily. Appears door needs to be lifted off and then ???Note "Fossil" - I'm not the most able mechanic or fixit guy, but I am very quick to learn and listen well. Any help or hints would be appreciated. Thank you. |
| Display Modes | |
| Door latch broken/Door locked | kitade | Dishwasher Repair | 2 | 10-23-2007 11:42 AM |
| outer black glass oven door | Lynn P | Oven Repair (including Ranges and Cooktops) | 1 | 10-16-2007 06:27 PM |
| Need to locate #14-37-331 black glass for oven door | Pegi | Oven Repair (including Ranges and Cooktops) | 1 | 10-14-2007 12:35 AM |
| Reassembling oven door glass | blasterman | Oven Repair (including Ranges and Cooktops) | 0 | 09-12-2007 11:47 PM |
| How to replace oven door glass? | mkguitar | Oven Repair (including Ranges and Cooktops) | 3 | 09-11-2007 03:43 PM |
