Discuss
replacing cooktop
 in
I have a hotpoint smooth top electric range and the cooktop is cracked and needs to be replaced. I'm
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » replacing cooktop
  #1 (permalink)
Old 10-27-2007, 03:01 PM
kenvan kenvan is offline
Junior Member
kenvan is on a distinguished road
Default replacing cooktop
Model Number: RB787WH1WW   Brand: Hotpoint   Age: 1 - 5 years
I have a hotpoint smooth top electric range and the cooktop is cracked and needs to be replaced. I'm just wondering if the job is easy to do or needs to be done professionally.
kenvan
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-27-2007, 03:47 PM
fixxit fixxit is offline
Senior Expert
APP Volunteer
fixxit is on a distinguished road
Default
is a relatively easy, but realy help to have extra hands. turn the power off. you just have to un screw 2 phillips screws in front. lift the front just like a car hood. you should see 2 rails with 2 burners each. should be 2 1/4 screws per rail (one on each side). un screw and lower to the oven top. pay attention to what the screw holes on the top so as to properly align the burners to the glass top. replace the top, return the burner rails, and voila! good luck and post your results
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cooktop igniters bobertj Oven Repair (including Ranges and Cooktops) 6 10-18-2008 08:25 PM
Replacing a Frigidaire glass cooktop assembly ajensenlsu Oven Repair (including Ranges and Cooktops) 3 06-28-2008 12:26 PM
G.E. cooktop Jeff Miller Oven Repair (including Ranges and Cooktops) 1 10-19-2007 05:13 PM
Thermador Cooktop Help jojo77 Oven Repair (including Ranges and Cooktops) 0 09-29-2007 01:04 PM
Replacing glass cooktop jennifer Oven Repair (including Ranges and Cooktops) 2 08-13-2007 12:46 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
