dlb
#1 Posted : Tuesday, January 6, 2009 9:38:18 PM(UTC)
dlb
I have a 7 year old Whirlpool gas wall oven, model SB160PEEB5. The oven went out on sick leave on Christmas Day. Wont light or heat. The broiler works fine. It has a hot bar type igniter which was getting nice and hot (bright orange) on Christmas but stopped working when I tried to check the amperage at the connector. Now it doesn't get warm at all. I bought a new igniter which will not get even warm either. I checked the voltage to the igniter which measured 14 volts with the oven on. Any suggestions as to what the problem might be. Thanks, Dave
#2 Posted : Thursday, January 8, 2009 10:20:12 AM(UTC)
Hi Dave,
Most likely the problem is a bad control board.
- The part number for the control board is AP2973415
Here are the break down diagrams for the Whirlpool oven Model SB160PEEB5
dlb
#3 Posted : Thursday, January 8, 2009 8:44:30 PM(UTC)
dlb
Hi Dave,
Thanks Gene, I would like to check the control board but so far I haven't figured out how to get into the board. Access to it isn't obvious to me. Dave (dlb)
Maytag CWG3600AAB Gas Wall Oven (Oven Repair (including Ranges and Cooktops))
by bdgabriel1 2/28/2022 7:07:47 AM(UTC)
JENN-AIR MODEL JGM8130DDM SLIDE IN GAS WALL OVEN (Oven Repair (including Ranges and Cooktops))
by Guest 11/21/2021 5:35:44 PM(UTC)
by sassylady1 6/18/2015 7:44:05 PM(UTC)
Whirlpool SB130PER4 Gas Wall oven doesn't heat (Oven Repair (including Ranges and Cooktops))
by sikhnerd 10/17/2012 10:00:32 AM(UTC)
Frigidaire gas wall oven- burner won't stay lit (Oven Repair (including Ranges and Cooktops))
by tkeller 7/19/2011 9:39:58 AM(UTC)
Ignitor for Tappan Gas Wall Oven (Oven Repair (including Ranges and Cooktops))
by tommurray 1/14/2011 10:31:58 PM(UTC)
tappan gas wall oven (Oven Repair (including Ranges and Cooktops))
by lneil216@yahoo.com 10/25/2010 2:16:11 PM(UTC)
MAYTAG Gas Wall Oven CONTROLS DOESNT WORKS (Oven Repair (including Ranges and Cooktops))
by luthien 9/27/2010 12:41:24 PM(UTC)
Gas Wall Oven SB160PEXQ1 wont Ignite! (Oven Repair (including Ranges and Cooktops))
by smckeone 4/21/2010 3:36:06 PM(UTC)
Maytag Gas Wall Oven Will Not Heat (Oven Repair (including Ranges and Cooktops))
by jpecobird1 6/30/2009 5:29:13 AM(UTC)
1982 Gas Wall oven will not heat (Oven Repair (including Ranges and Cooktops))
by trikerdave 4/21/2009 2:14:41 PM(UTC)
Jenn Air gas wall oven won't ignite (Oven Repair (including Ranges and Cooktops))
by tamcasey 11/12/2008 8:32:44 PM(UTC)
Gas wall oven will not light (Oven Repair (including Ranges and Cooktops))
by Marrel 6/12/2008 12:13:15 PM(UTC)
