I have a microwave oven combination unit. After a power outage the microwave stopped working. after a week of trying to fix it, I replaced a line fuse which fixed the microwave but somehow stopped the oven from heating? The only things I messed with was taking the control panel off and on to get inside, and flipping the circuit off and on when working. ANy ideas? another fuse?
Check if both circuit breakers are "on". Open the control panel and check for any loose wire.
both circuits are on and there is no damage to the wires i can see, i was careful when unplugging them.
