Discuss
Oven Pilot light blows out
 in
My mother-in-law's gas stove has a problem with the pilot light going out for her oven. I
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Pilot light blows out
  #1 (permalink)
Old 01-06-2009, 02:13 PM
Ron Smith Ron Smith is offline
Junior Member
Ron Smith is on a distinguished road
Question Oven Pilot light blows out
Model Number: CG3110PPW   Brand: Crosley   Age: More than 10 years
My mother-in-law's gas stove has a problem with the pilot light going out for her oven. I can light it up, but if the oven door is shut too quickly the air blows out the pilot again. Can I replace or clean a part to strengthen the flame?
Related Models
Crosley CG3110PPW Range - F/s Std Gas
Crosley CG3110PRA Range - F/s Std Gas
Crosley CG3110PRV Range - F/s Std Gas
Crosley CG3110PRW Range - F/s Std Gas
Crosley CG31200ADQ Range - F/s Std Gas
Crosley CG31200ADV Range - F/s Std Gas
Crosley CG31200ADW Range - F/s Std Gas
Crosley CG31200BDQ Range - F/s Std Gas
Crosley CG31200BDV Range - F/s Std Gas
Crosley CG31200BDW Range - F/s Std Gas
Crosley CG3120SPA Range - F/s Std Gas
Crosley CG3120SPN Range - F/s Std Gas
Crosley CG3120SPW Range - F/s Std Gas
Crosley CG3120SRA Range - F/s Std Gas
Crosley CG3120SRW Range - F/s Std Gas
Crosley CG3131WRA Range - F/s Std Gas
Crosley CG3131WRW Range - F/s Std Gas
Crosley CG3131WUA Range - F/s Std Gas
Crosley CG3131WUW Range - F/s Std Gas
Crosley CG3131XRA Range - F/s Std Gas
Crosley CG3131XRW Range - F/s Std Gas
Crosley CG3131XUA Range - F/s Std Gas
Crosley CG3131XUW Range - F/s Std Gas
Crosley CG3137XUA Range - F/s Std Gas
Crosley CG3137XUW Range - F/s Std Gas
Crosley CG31400ADW Range - F/s Std Gas
Crosley CG31600ADB Range - F/s Std Gas
Crosley CG31600ADQ Range - F/s Std Gas
Crosley CG31600ADV Range - F/s Std Gas
Crosley CG3177VRV Range - F/s Std Gas
Crosley CG3177VUV Range - F/s Std Gas
Crosley CG3177XRA Range - F/s Std Gas
Crosley CG3177XRW Range - F/s Std Gas
Crosley CG3177XUA Range - F/s Std Gas
Crosley CG3177XUW Range - F/s Std Gas
Crosley CG3231XRA Range - F/s Cont Clean Gas
Crosley CG3231XRW Range - F/s Cont Clean Gas
Crosley CG3231XUA Range - F/s Cont Clean Gas
Crosley CG3231XUW Range - F/s Cont Clean Gas
Crosley CG34300ADA Range - S/c F/s Gas
Crosley CG34300ADT Range - S/c F/s Gas
Crosley CG34300ADW Range - S/c F/s Gas
Crosley CG3432SRA Range - S/c F/s Gas
Crosley CG3432SRW Range - S/c F/s Gas
Crosley CG3432XRA Range - S/c F/s Gas
Crosley CG3432XRW Range - S/c F/s Gas
Crosley CG3438SRA Range - S/c F/s Gas
Crosley CG3438SRW Range - S/c F/s Gas
Crosley CG34700ADD Range - S/c F/s Gas
Crosley CG34700ADQ Range - S/c F/s Gas
Crosley CG34700ADV Range - S/c F/s Gas
Crosley CG34700BDQ Range - S/c F/s Gas
Crosley CG34700BDT Range - S/c F/s Gas
Crosley CG34700BDV Range - S/c F/s Gas
Crosley CG34700BDW Range - S/c F/s Gas
Crosley CG3478VVD Range - S/c F/s Gas
Crosley CG3478VVV Range - S/c F/s Gas
Crosley CG3478XRA Range - S/c F/s Gas
Crosley CG3478XRW Range - S/c F/s Gas
Crosley CG3478XVA Range - S/c F/s Gas
Crosley CG3478XVW Range - S/c F/s Gas
Crosley CG34800ADQ Range - F/s Std Gas
Crosley CG34800ADS Range - F/s Std Gas
Crosley CG34800ADT Range - F/s Std Gas
Crosley CG34800ADV Range - F/s Std Gas
Crosley CG34800ADW Range - F/s Std Gas
Crosley CG34800BDS Range - S/c F/s Gas
Crosley CG4131WRA Range - F/s Std Gas
Crosley CG4131WRW Range - F/s Std Gas
Crosley CG4151WTA Range - F/s Std Gas
Crosley CG4151WTW Range - F/s Std Gas
Hardwick CG4612MA539RG Range - F/s Std Gas
Hardwick CG4612MW539RG Range - F/s Std Gas
Hardwick CG4616MA429RG Range - F/s Std Gas
Hardwick CG4616MW429RG Range - F/s Std Gas
Hardwick CG4622MA429RG Range - F/s Std Gas
Hardwick CG4622MA439RG Range - F/s Std Gas
Hardwick CG4622MA539RG Range - F/s Std Gas
Hardwick CG4622MW429RG Range - F/s Std Gas
Hardwick CG4622MW439RG Range - F/s Std Gas
Hardwick CG4622MW539RG Range - F/s Std Gas
Hardwick CG4622MY539RG Range - F/s Std Gas
Hardwick CG4642MA639RG Range - F/s Std Gas
Hardwick CG4642MW639RG Range - F/s Std Gas
Crosley CG6498VVA Range - S/c S/i Gas
Crosley CG6498VVV Range - S/c S/i Gas
Hardwick CG7241A819R Walloven - Cont Clean Gas
Crosley CG8211PA Surface Unit - Gas
Crosley CG8211PS Surface Unit - Gas
Crosley CG8211PW Surface Unit - Gas
Amana CG8409W Dryer - Gas
Amana CG8409W2 Dryer - Gas
Hardwick CG8422MA729RG Walloven - Std Dbl Oven Gas
Hardwick CG8422MW729RG Walloven - Std Dbl Oven Gas
Hardwick CG8422MY729RG Walloven - Std Dbl Oven Gas
Crosley CG9222XPB Walloven - Cont Clean Gas
Hardwick CG9441B9R Range - D/i Std Gas
Hardwick CG9616A429R Range - F/s Std Gas
Hardwick CG9616A429RW Range - F/s Std Gas
Hardwick CG9616A79R Range - F/s Std Gas
Hardwick CG9616W429R Range - F/s Std Gas
Hardwick CG9616W429RW Range - F/s Std Gas
Hardwick CG9616W79R Range - F/s Std Gas
Hardwick CG9617A439R Range - F/s Std Gas
Hardwick CG9617W439R Range - F/s Std Gas
Hardwick CG9617W540R Range - F/s Std Gas
Hardwick CG9617W540RG Range - F/s Std Gas
Hardwick CG9617W540RQ Range - F/s Std Gas
Hardwick CG9617W560RQ Range - F/s Std Gas
Hardwick CG9617W570R Range - F/s Std Gas
Hardwick CG9621A539R Range - F/s Std Gas
Hardwick CG9621W539R Range - F/s Std Gas
Frigidaire CGA1M2WE Gib(v2) / Gas Range
Frigidaire CGA1M2WSE Gib(v1) / Gas Range
Frigidaire CGA1M2WSTA Gib(v1) / Free Standing Gas Range
Frigidaire CGA1M2WSTB Gib(v2) / Free Standing Gas Range
Frigidaire CGA1M2WSTC Gib(v1) / Gas Range
Frigidaire CGA1M2WSTD Gib(v1) / Gas Range
Frigidaire CGA1M3WSTA Gib(v3) / Free Standing Gas Range
Frigidaire CGA1M3WSTB Gib(v1) / Gas Range
  #2 (permalink)
Old 01-07-2009, 04:46 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Default
Hi Ron,
You can try to clean the pilot using a small needle, but I would recommend just to replace it.
- The part number for the oven pilot is AP4095214
Here are the break down diagrams for the Crosley range Model CG3110PPW
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cant light pilot on oven Theron Mills Oven Repair (including Ranges and Cooktops) 1 10-07-2009 02:27 PM
oven won't light , pilot works Holiday Oven Repair (including Ranges and Cooktops) 1 06-12-2009 07:46 PM
magic chef propane oven won't light (has pilot light) A and J Oven Repair (including Ranges and Cooktops) 3 09-19-2008 12:36 PM
oven won't light-pilot is off cherylk Oven Repair (including Ranges and Cooktops) 0 01-01-2008 08:10 AM
Which thermocouple? Pilot is on, oven won't light docnpat Oven Repair (including Ranges and Cooktops) 1 12-31-2007 01:32 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
