Discuss
bottom oven filament won't heat up
 in
bottom heating element for oven won't heat up. Unit is over 20 years old but otherwisw works well. Related Models
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » bottom oven filament won't heat up
  #1 (permalink)
Old 03-30-2011, 11:18 AM
Junior Member
whiting is on a distinguished road
Default bottom oven filament won't heat up
Model Number: Jhp61goh2ad   Brand: GE   Age: More than 10 years
Related Models
General Electric JHP62G*M1 Hi-low range
General Electric JHP62GN1 Electric range
General Electric JHP62GN2 Hi-low range
General Electric JHP62GN3AD Electric range
General Electric JHP62GN3WH Electric range
General Electric JHP62GN4AD Electric range
General Electric JHP62GN4WH Electric range
General Electric JHP62GN5AD Electric range
General Electric JHP62GN5WH Electric range
General Electric JHP62GN6AD Electric range
General Electric JHP62GN6WH Electric range
General Electric JHP62N*K1 Hi-low range
General Electric JHP62N*K2 Hi-low range
General Electric JHP62N*K3 Hi-low range
General Electric JHP62N*K4 Hi-low range
General Electric JHP62N*K5 Hi-low range
General Electric JHP62V*K1 Hi-low range
General Electric JHP62V*K2 Hi-low range
General Electric JHP62V*K3 Hi-low range
General Electric JHP62V*K4 Hi-low range
General Electric JHP62V*K5 Hi-low range
Maytag JHP636 JADE HOT PLATES (COOKING GAS)
General Electric JHP63G*H1 Hi-low range
General Electric JHP63G*J1 Hi-low range
General Electric JHP63G*J2 Hi-low range
General Electric JHP63G*J3 Hi-low range
General Electric JHP63G*M1 Hi-low range
General Electric JHP63GN1 Electric range
General Electric JHP63GN2 Hi-low range
General Electric JHP63GN3AD Electric range
General Electric JHP63GN3WH Electric range
General Electric JHP63GN4AD Electric range
General Electric JHP63GN4WH Electric range
General Electric JHP63GN5AD Electric range
General Electric JHP63GN5WH Electric range
General Electric JHP63V*K1 Hi-low range
General Electric JHP63V*K2 Hi-low range
General Electric JHP63V*K3 Hi-low range
General Electric JHP63V*K4 Hi-low range
General Electric JHP63V*K5 Hi-low range
General Electric JHP64G*L1 Hi-low range
General Electric JHP64V*L1 Hi-low range
General Electric JHP65G*01 Hi-low range
General Electric JHP65G*02 Hi-low range
General Electric JHP65G*D1 Hi-low range
General Electric JHP66G*01 Hi-low range
General Electric JHP66G*02 Hi-low range
General Electric JHP67G*D1 Hi-low range
General Electric JHP67G*D2 Hi-low range
General Electric JHP67G*D3 Hi-low range
General Electric JHP67G*H1 GE HI/LOW COOKING CENTER
General Electric JHP67G*H2 Hi-low range
General Electric JHP67G*V5 Hi-low range
General Electric JHP68G*01 Hi-low range
General Electric JHP68G*02 Hi-low range
General Electric JHP69G*H2 Hi-low range
General Electric JHP69G*J1 Hi-low range
General Electric JHP69G*K1 Hi-low range
General Electric JHP69G*K2 Hi-low range
General Electric JHP69G*K3 Hi-low range
General Electric JHP69G*K4 Hi-low range
General Electric JHP69G*K5 Hi-low range
General Electric JHP69GN1 Hi-low range
General Electric JHP69GN2 Hi-low range
General Electric JHP69GN3AD Electric range
General Electric JHP69GN3WH Electric range
General Electric JHP69GN4AD Electric range
General Electric JHP69GN4WH Electric range
General Electric JHP70G*M1 Hi-low range
General Electric JHP70GN1 Hi-low range
General Electric JHP70GN2 Hi-low range
General Electric JHP70GN3AD Electric range
General Electric JHP70GN3WH Electric range
General Electric JHP70GN4AD Electric range
General Electric JHP70GN4WH Electric range
General Electric JHP70GN5AD Electric range
General Electric JHP70GN5WH Electric range
General Electric JHP70N*K1 Hi-low range
General Electric JHP70N*K2 Hi-low range
General Electric JHP70N*K3 Hi-low range
General Electric JHP70N*K4 Hi-low range
General Electric JHP70N*K5 Hi-low range
General Electric JHP70V*K1 Hi-low range
General Electric JHP70V*K2 Hi-low range
General Electric JHP70V*K3 Hi-low range
General Electric JHP70V*K4 Hi-low range
General Electric JHP70V*K5 Hi-low range
General Electric JHP75G*01 Hi-low range
General Electric JHP75G*02 Hi-low range
General Electric JHP75G*03 Hi-low range
General Electric JHP75G*D1 Hi-low range
Maytag JHP848 JADE HOT PLATES (COOKING GAS)
General Electric JHP97G*D1 Hi-low range
General Electric JHP97G*Y2 Hi-low range
General Electric JHP97G*Y3 Hi-low range
General Electric JHP97G*Y5 Hi-low range
General Electric JHP97G*Y6 Hi-low range
General Electric JHP98G*Y2 Hi-low range
General Electric JHP98G*Y3 Hi-low range
General Electric JHP98G*Y4 Hi-low range
General Electric JHP98G*Y5 Hi-low range
Maytag JHPE2218 ELEVATED HOT PLATE (COOKING GAS)
Maytag JHPE2224 ELEVATED HOT PLATE (COOKING GAS)
Maytag JHPE3324 ELEVATED HOT PLATE (COOKING GAS)
Maytag JHPE3336 ELEVATED HOT PLATE (COOKING GAS)
Maytag JHPE4336 ELEVATED HOT PLATE (COOKING GAS)
Whirlpool JHWS160ACR4 HOT WATER DISPENSER
Whirlpool JHWS160AWH4 HOT WATER DISPENSER
General Electric JIC100H1 Electric range
Jenn-Air JIC4430XB00 30" INDUCTION COOKTOP
Jenn-Air JIC4430XS00 30" INDUCTION COOKTOP
Jenn-Air JIC4536XB00 36" INDUCTION COOKTOP
Jenn-Air JIC4536XS00 36" INDUCTION COOKTOP
Jenn-Air JIM1550ACX UNDERCOUNTER BUILT IN ICE MAKER
Jenn-Air JIM1550ARB UNDERCOUNTER BUILT IN ICE MAKER
Jenn-Air JIM1550ARS UNDERCOUNTER BUILT IN ICE MAKER
Jenn-Air JIM1550ARW UNDERCOUNTER BUILT IN ICE MAKER
Maytag JIM158XBCX0 ICE CUBE MAKER
Maytag JIM158XBCX1 ICE CUBE MAKER
Maytag JIM158XBCX2 ICE CUBE MAKER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bottom oven, bottom heating element won't heat weber7062 Oven Repair (including Ranges and Cooktops) 0 02-28-2011 02:38 PM
Main oven does not heat but the stove top and the bottom oven work wes2ii Oven Repair (including Ranges and Cooktops) 5 09-23-2010 01:22 PM
Bottom oven element won't heat up HammerJ88 Oven Repair (including Ranges and Cooktops) 0 03-05-2010 05:43 PM
Bottom burner of oven will not heat angievpark Oven Repair (including Ranges and Cooktops) 3 12-18-2008 09:21 AM
Oven doesnt heat on bottom but..... jeffreyb Oven Repair (including Ranges and Cooktops) 1 11-04-2007 07:04 AM
