yeller123
#1 Posted : Tuesday, January 6, 2009 6:19:51 AM(UTC)
yeller123
I have a GE profile dual convection oven. After running the 4 hour self clean cycle on the top oven, the door won't unlock. Tried shutting the breaker off, running a partial clean cycle, etc. The locked light finally went off, however door still locked and when you try to turn oven on, you get the locked door error. Any sugestions on how to get it open?
#2 Posted : Tuesday, January 6, 2009 8:04:48 PM(UTC)
In order to open the door you have to open the control panel and remove the door lock.
Remove the three screws from the bottom of the control panel. You'll heed a 1/4" open wrench. Pull the bottom of the control panel toward yourself and push it up to release from the upper tabs.
The door lock is secured by the three screws.
yeller123
#3 Posted : Saturday, January 31, 2009 7:06:43 AM(UTC)
yeller123
Thanks Gene. I replaced to door lock assembly and it is now working, except that the lock order is reversed, i.e. when self clean is started it goes to unlock mode and when self clean is shut off, the door locks. I tried shutting off the power during the self clean cycle, however when power is applied, it locks the door again. Any suggestions? Thanks
#4 Posted : Saturday, January 31, 2009 9:39:24 PM(UTC)
Looks like you switched around wires to the door latch switches. There suppose to be the tech sheets with the wiring diagram inside the control panel. Check which wire where goes.
