Discuss
Caloric Gas Even slow to Ignite & heat up
 in
You can smell gas rather strong before the even ignites, and then it take 5 - 10 - 15 minutes or more
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Caloric Gas Even slow to Ignite & heat up
  #1 (permalink)
Old 10-26-2007, 02:33 PM
Dwbradley Dwbradley is offline
Junior Member
Dwbradley is on a distinguished road
Default Caloric Gas Even slow to Ignite & heat up
Model Number: RST376   Brand: Caloric   Age: More than 10 years
You can smell gas rather strong before the even ignites, and then it take 5 - 10 - 15 minutes or more before the Temp., starts to increase. I have no idea what componet needs replaced, if this is an igniter or gas value issue. The primary appliance replair shop does not service this brand. Any advice would be appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-26-2007, 02:49 PM
fixxit fixxit is offline
Senior Expert
APP Volunteer
fixxit is on a distinguished road
Default
sounds like more than one issue. start by visualy checking the ignitor, look for a white or ashy spot. if so this is one likely problem. you might also check for a faulty gas valve (use a non-cumbustable light source) if the smell is Very strong use a leak detector (cheapest version of this is regular dish soap and water). look for the bubbles. may be just a loose gas connector. if not you may want to replace the gas valve
  #3 (permalink)
Old 10-26-2007, 03:00 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Dwbradley
Are we talking about bake or broil modes?
If the problem is with the bake then most likely the igniter is bad and has to be replaced.
If the problem is with broil then I would inspect the broil burner first for any size of holes in the net. Replace the burner if you found one. The igniter for the broil burner has to be replaced in any way.
The igniters for the bake and for the broil are the same. You have to use the bracket from the old igniter.
- The part number for the new igniter AP2934763
- The part number for the broil burner AP55224
- Here are the break down diagrams for the Caloric range Model RST376
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Burner won't ignite flaumbetty Oven Repair (including Ranges and Cooktops) 5 01-25-2008 06:39 AM
Oven won't ignite under 350 holtzlou Oven Repair (including Ranges and Cooktops) 0 09-13-2007 06:39 AM
Caloric Convection Oven caloricgold Oven Repair (including Ranges and Cooktops) 0 09-03-2007 07:45 PM
Old Caloric Oven: irregular ignition and won't hold a temperature mhrichardson99 Oven Repair (including Ranges and Cooktops) 0 08-23-2007 10:20 AM
Oven does not ignite Dan Damiata Oven Repair (including Ranges and Cooktops) 0 08-09-2007 07:36 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
