| » Control Box dead - BOTH of them |
Model Number: JTP20 Brand: GE Age: 1 - 5 years
GE 30" all-electric 240v oven, no prior issues.
Part in question: Control Box - ERC3B, aka WBT27T10411 I can't say exactly when the oven stopped working. We were away on vacation for 2 weeks, and the house sitter claims she never so much as glanced at the oven. It's plausible, she's vegan. The condition of the oven is/was nothing worked - no display, no beeps, no oven light. I reset the circuit breaker even though it hadn't tripped. No change. So, I initially blamed it on the squirrel that had taken up residence in the space between our first and second floor - from where the electric wires begin to distribute themselves around the house. It took several weeks, but the squirrel is gone, and I owe it an apology because it hadn't pee'd on or chewed through the wires as I had expected. I tested the line at the circuit breaker, and the breaker itself. They're fine. I also tested the wires at the junction box in the kitchen; good. Testing between the red wire on L2 and the black wire on L1 gives me a reading of 240v, as it should. L1 to N, however, doesn't give me the expected 120v, but 1.4v. L1 to J4 7 also reads at 1.4v. So I ordered a replacement Control Box. The replacement arrived in short order, and except for the color of the Key Panel ribbon connector, it is an exact match for the original part. I photographed the original prior to removing any wires, and swapped the Control Box out. It took all of about 15 minutes. Unfortunately, the net change was: 0. No display, no beeps, no oven light. I have since isolated and checked every component and every wire - even the oven light bulb. I have continuity everywhere, and tested the key panel as well. So, unless there's a circuit breaker or a relay on the inside of the Control Box, or some other explanation, I suspect I got a bad replacement part. Any ideas? Mike Update, 31-Mar-11: Got an email from anonymous technician suggesting I test the thermal switches. Whereas I appreciated getting a response, I apparently wasn't clear enough when, in paragraph 6, I stated, "I have since isolated and checked every component ... I have continuity everywhere...". (deep sigh) I just spoke to someone from APP, and a new ERC3B is going to be shipped out. Ads By Google Related Models Last edited by MikeJL : 03-30-2011 at 01:58 PM. Reason: Update |
| Display Modes | |
| Control panel dead. | tjjn | Oven Repair (including Ranges and Cooktops) | 0 | 02-28-2011 10:16 AM |
| Control Panel dead | SJSonARF | Oven Repair (including Ranges and Cooktops) | 5 | 10-22-2010 06:18 AM |
| Dead control panel | caldwell.70 | Dryer Repair | 3 | 10-23-2009 06:01 AM |
| Control Panel is dead | rileyd | Oven Repair (including Ranges and Cooktops) | 3 | 10-13-2009 05:10 PM |
| Gas Cookto Control Dead | VABEAR | Oven Repair (including Ranges and Cooktops) | 6 | 08-01-2009 08:03 AM |
