The flat glass cook top has 4 sections-4 sets of rings/, and on one set/section, only one ring heats up. The rest of the sets/sections heat up normally.
Can this one section be repaired to full operation?
WB
If you had a meter it would be great. If you had a meter to check the terminal on the switch, that would be the way to go. If I were to take an educated guess, I would replace the switch. Tom ApplianceEducator.com
