I have a black whirlpool double oven and it will not do anything.Last week i got an error code e6-f2.It went away and the oven started working about a day.Then it quit again.Sometimes it will beep twice and then three times and that is it.I pushed all the buttons and now it will not do anything
1. Check keypad connector for firm connection (keypad connects to control board). 2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
That is what the manual says for your oven. Tom
