| » Help with Kenmore Oven |
Model Number: 362.75585891 Brand: Kenmore Age: 1 - 5 years
We received this oven used from a relative. When I turn on the oven I can smell gas, and it takes quite a while for it to reach temperature. I was told by a friend that I probably needed a thermocoupler, but when I went to live chat here on the site I was told it couldn't be found for this particular model. Any help would be greatly appreciated.
Thanks! Michele |
many newer (less than 5 years) gas ovens will read resistance from the glow bar (ignitor) as a type of thermocouple. visualy check the glow bar for discolorations, specificly an ashy spot. if this is the case it is likely your problem. also check you modle # (likely on either the left or right side front when you open the lower drawer
Last edited by fixxit : 10-26-2007 at 01:18 PM. Reason: needed correct model # for further information |
Hi mmorgan100
Most likely the problem with your oven is a bad bake igniter. Replacing it should solve the problem. The bake igniter - The part number for the new igniter AP2020569 Good luck. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Keep me updated, please.
__________________
| Display Modes | |
| Kenmore Gas Oven | abimael64 | Oven Repair (including Ranges and Cooktops) | 1 | 08-20-2007 05:38 PM |
