Hi. My oven has been burning everything and we just figured out it's because its not turning off even when it reaches the adequate temperature - I had to disconnect the gas to get it to stop heating when I last turned it on. The broiler and everything else is working fine, though. Any ideas?
Did you try to unplug the range to stop heating before you turned the gas "off"?
Yeah, I even unplugged the range and even then the oven wouldn't turn off, not till I actually disconnected the gas. I then plugged it back in and the oven top and broiler work fine, but as soon as I turn the oven on it won't turn off.
Most likely the problem is a relay on the control board which stuck closed. In order to provide the right part number for the control board I need the color of the touch pad and a digit after "S" in the model number.
The only digit I see after the model number is Series "3" and the touch pad is mostly black (some gray buttons)
Gene, thanks for you r help so far but did you get this last bit of information you asked about?
Sorry for the delay. The part number for the control board is AP3085520Gene.
