I purchased an electric control panel from parts pros. I have begun the replacement of said part. I removed old control panel and began installing the new part. The last wire I was connecting was the ribbon from the touch pad. It appears that the ribbon connector on the electric control panel has changed (made larger) and ribbon does not fit properly. Do I need to replace touch pad also, or is there an adapter or something to make it fit correctly? Thanks
