Discuss
Oven Not coming up to full temp
 in
Hello Everyone Our Amana oven does not come up to temp. The broiler and self cleaning option work and the
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven Not coming up to full temp
  #1 (permalink)
Old 03-27-2011, 10:04 AM
Junior Member
Montyb is on a distinguished road
Default Oven Not coming up to full temp
Model Number: ARG7102L   Brand: Amana   Age: 5 - 10 years
Hello Everyone
Our Amana oven does not come up to temp. The broiler and self cleaning option work and the stove top works. Reading various forums I came to the conclusion that the igniter needed replacing. This was done 5+ years ago when the oven would not heat up. I went ahead and replaced the igniter and it still doesn't come up to temp. So now I am stumped as to why. Could this be a control board problem instead of the igniter or some other problem?
Thanks for any input on this matter.
Related Models
Amana ARG7102L RANGE- S/C S/I DDRAFT GAS
Amana ARG7102L RANGE- S/C F/S GAS
Amana ARG7102L Range - S/c S/i Ddraft Gas
Amana ARG7102W RANGE- S/C F/S GAS
Amana ARG7102W RANGE- S/C S/I DDRAFT GAS
Amana ARG7200L RANGE- S/C S/I DDRAFT GAS
Amana ARG7200W RANGE- S/C S/I DDRAFT GAS
Amana ARG7202 E RANGE- S/C S/I DDRAFT GAS
Amana ARG7300LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7300W RANGE- S/C S/I DDRAFT GAS
Amana ARG7300WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7301L RANGE- S/C S/I DDRAFT GAS
Amana ARG7301LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7301W RANGE- S/C S/I DDRAFT GAS
Amana ARG7301WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7302CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7302LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7302WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7303CC RANGE- S/C F/S GAS
Amana ARG7303LL RANGE- S/C F/S GAS
Amana ARG7303WW RANGE- S/C F/S GAS
Amana ARG7600CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7600L RANGE- S/C S/I DDRAFT GAS
Amana ARG7600L RANGE- S/C F/S GAS
Amana ARG7600LL RANGE- S/C S/I DDRAFT GAS
Amana ARG7600W RANGE- S/C S/I DDRAFT GAS
Amana ARG7600WW RANGE- S/C S/I DDRAFT GAS
Amana ARG7600WW RANGE- S/C F/S GAS
Amana ARG7800CC RANGE- S/C S/I DDRAFT GAS
Amana ARG7800E RANGE- S/C S/I DDRAFT GAS
Amana ARG7800LL RANGE- S/C S/I DDRAFT GAS
  #2 (permalink)
Old 03-28-2011, 06:52 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
Quote:
Originally Posted by Montyb View Post
Hello Everyone
Monty,
Based on your post, you may want to start at the oven temperature sensor.
Under certain circumstances, the sensor can develop a problem at the lower temperature sensor resistances.
Temperature Sensor Resistance
75 degrees F 1075 ohms
350 degrees F 1625 ohms
550 degrees F 2025 ohms
You may want to start there .
Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven heats up to Temp, but wont light back up to keep at temp Pooler Oven Repair (including Ranges and Cooktops) 1 05-06-2014 07:46 AM
oven temp selector and temp in oven varies significantly larry68417 Oven Repair (including Ranges and Cooktops) 1 11-12-2010 07:02 PM
Jenn Air not coming up to temp blazer_0006 Oven Repair (including Ranges and Cooktops) 1 08-29-2010 08:28 AM
oven not coming up to temp happy 1963 Oven Repair (including Ranges and Cooktops) 0 03-25-2010 07:30 PM
Making high pitch noise as if trying to start compressor and high temp alarm coming Dbengali Refrigerator & Freezer Repair 2 06-22-2009 09:14 AM
