ISSUE: 1 of 4 burners lite itself (RR). 3 of 4 burner ignitors spark (LR, RR, LF), but will only lite IF I use the RR burner/ignition dial. So, in other words, if I want to use the self ignition for either the LF or LR burner, I have to turn the RR dial to LITE, and then turn the LF or LR burner on to auto ignite.The RF burner will only lite with an external flame source, and the auto ignitor does not spark.
MY IDEA: The obvious is to the replace the ignitor on the RF burner in its entirety. The weirdness of the Left side auto ignition being controlled by the Right Rear dial has me stumped. I am thinking I need to replace the electronic ignition control module, but I am uncertain. I've checked the wiring diagram and it appears correct.
Insights MUCH appreciated. Thanks in advance for your comments!:D
Brian
