madubo8
#1 Posted : Sunday, January 4, 2009 5:08:10 AM(UTC)
madubo8
This morning when I turned on my oven, It tripped the breaker.
After checking wiring, I reset the breaker and pressed clear/off on the display.
12:00 flashed for a second and then
dr-C appeared on the display.
I cannot find this code anywhere, any help?
Frigidaire Range FPES3085KFA (Oven Repair (including Ranges and Cooktops))
by walk7078 10/25/2022 3:54:30 PM(UTC)
Frigidaire Range/Stove/Oven: Model FPGF3081KFJ (Oven Repair (including Ranges and Cooktops))
by Guest 8/10/2022 8:26:48 AM(UTC)
Frigidaire Range Control Board Issue (Oven Repair (including Ranges and Cooktops))
by grpuzojr 6/18/2022 4:29:02 PM(UTC)
Frigidaire range burner not working (Oven Repair (including Ranges and Cooktops))
by Hatt65 12/6/2020 11:35:18 AM(UTC)
Frigidaire range backguard removal help (Dishwasher Repair)
by ReginaH 3/1/2020 5:58:25 AM(UTC)
Frigidaire range won't bake (Oven Repair (including Ranges and Cooktops))
by lenjack 6/17/2018 2:25:06 PM(UTC)
Removing Cooktop on a Frigidaire Range (Oven Repair (including Ranges and Cooktops))
by smwilliams 5/12/2015 8:57:01 AM(UTC)
Frigidaire range - No Display (Oven Repair (including Ranges and Cooktops))
by hambob64 1/19/2015 5:59:15 PM(UTC)
Frigidaire range oven problem... (Oven Repair (including Ranges and Cooktops))
by Cr00zng 4/22/2013 7:58:08 AM(UTC)
Frigidaire Range,main Panel. (Oven Repair (including Ranges and Cooktops))
by bthdlm 3/4/2013 9:57:05 AM(UTC)
Frigidaire Range FEF365ASG won't bake or heat oven chamber (Oven Repair (including Ranges and Cooktops))
by lostsole1976 1/7/2013 11:03:19 AM(UTC)
Frigidaire Range F10 Error (Oven Repair (including Ranges and Cooktops))
by Cephus 8/9/2012 1:37:10 PM(UTC)
Latch Door Motor for Frigidaire Range (Oven Repair (including Ranges and Cooktops))
by hecman 4/17/2012 11:52:02 AM(UTC)
RCI-75-62 Frigidaire Range (Oven Repair (including Ranges and Cooktops))
by keysrose 3/28/2012 1:40:39 PM(UTC)
Frigidaire Range Control Panel Dead (Oven Repair (including Ranges and Cooktops))
by Bruce7799 12/15/2011 5:11:43 PM(UTC)
