Discuss
Convection Oven not heating well
 in
I have a Gaggenau convection oven. The conventional heating elements work, however when the oven in on convection I cannot
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Convection Oven not heating well
  #1 (permalink)
Old 10-25-2007, 09:29 AM
russ hibbeler russ hibbeler is offline
Junior Member
russ hibbeler is on a distinguished road
Unhappy Convection Oven not heating well
Model Number: EB846-620   Brand: -other-   Age: More than 10 years
I have a Gaggenau convection oven. The conventional heating elements work, however when the oven in on convection I cannot get proper heating. Any idea as to why or how to fix this. Would it be difficult for me to fix it? The fan works, but there is not a significant amount of heat.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-04-2007, 11:47 AM
candewish candewish is offline
Junior Member
candewish is on a distinguished road
Default GAGGENAU 846-6xx oven convection heater failure
I had a similar failure some months ago and was told by the local
Gaggenau repair person that the heating element is no longer
available. I have spent some time searching but have not found
a replacement element.
If you discover one, please let me know -
candewish@yahoo.com
ps - from the exploded parts view provided by the gaggenau site,
I believe the part we need is # 097855. I have no idea what is involved
in a DIY repair - it only took the service person 15 minutes to diagnose
the failure.
PPS - a few weeks later I found a video on replacement of the convection
oven element, found the element, ordered it and in about one hour replaced
it. If you are handy and want more info, let me know at the above address.
Dec. 6, 2007
  #3 (permalink)
Old 12-05-2007, 11:26 AM
annegiacalone annegiacalone is offline
Junior Member
annegiacalone is on a distinguished road
Default Convection Oven Will Not Heat
Hi there,
I have the same problem with my Bosch Convection oven, any suggestions very much appreciated.
  #4 (permalink)
Old 12-11-2007, 12:17 PM
Junior Member
Default convection heating element failure
The following will produce several google hits -
how to repair convection oven
One of the hits is -
Video:**How to change a fan oven element and fan motor | eHow.com
1) to diagnose the problem, there is usually a grill in the back of the
oven that covers the heating element. Removing it allows inspection
of the element. Mine was obviously burned out. There are several
sites that can be used to find replacement elements. Ask if you
have problems.
2) I can give you a step-by-step sequence if you decide to repair
yourself. I would have used a repair company but those I tried were
too brain damaged to find a part. It took me about two hours of work
to make the repair, but there was some careful planning to get the
built in oven out in order to do the repair (and get it back in!). But
hey, it's working now!!!!!
3) I believe Gaggenau and Bosch ovens are similar.
Good luck ...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Caloric Convection Oven caloricgold Oven Repair (including Ranges and Cooktops) 0 09-03-2007 07:45 PM
micro wave convection oven bobalo Microwave Repair 1 08-21-2007 03:10 AM
Convection Oven wedofood Oven Repair (including Ranges and Cooktops) 0 08-14-2007 01:01 PM
Convection oven not heating (microwave working fine) rm625 Microwave Repair 0 08-13-2007 04:41 PM
Jenn-Air Radiant Range with Convection Oven Dee Oven Repair (including Ranges and Cooktops) 0 07-24-2007 05:11 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
