Discuss
Gas Range door hinge replacement
 in
Spring on left door hinge broke. Tried to get to hinge with no success. Cannot remove side panel. Looks like
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Gas Range door hinge replacement
  #1 (permalink)
Old 03-23-2011, 12:55 PM
Junior Member
jtmcvickar is on a distinguished road
Default Gas Range door hinge replacement
Model Number: CRG9700BAL   Brand: Maytag   Age: More than 10 years
Spring on left door hinge broke. Tried to get to hinge with no success. Cannot remove side panel. Looks like top must be removed along with other trim. Need instructions to get to and replace hinge.
Related Models
Maytag CRG9700BAL RANGE- S/C F/S GAS
Maytag CRG9700BAW RANGE- S/C F/S GAS
Maytag CRG9700CAE RANGE- S/C F/S GAS
Maytag CRG9700CAL RANGE- S/C F/S GAS
Maytag CRG9700CAM RANGE- S/C F/S GAS
Maytag CRG9700CAW RANGE- S/C F/S GAS
Admiral CRG9700CGE RANGE- S/C F/S GAS
Admiral CRG9700CGM RANGE- S/C F/S GAS
Maytag CRG9800AAB RANGE- S/C F/S GAS
Maytag CRG9800AAE RANGE- S/C F/S GAS
Maytag CRG9800AAL RANGE- S/C F/S GAS
Maytag CRG9800AAW RANGE- S/C F/S GAS
Maytag CRG9800BAB RANGE- S/C F/S GAS
Maytag CRG9800BAE RANGE- S/C F/S GAS
Maytag CRG9800BAL RANGE- S/C F/S GAS
Maytag CRG9800BAM RANGE- S/C F/S GAS
Maytag CRG9800BAW RANGE- S/C F/S GAS
Maytag CRG9800CAB RANGE- S/C F/S GAS
Maytag CRG9800CAE RANGE- S/C F/S GAS
Maytag CRG9800CAM RANGE- S/C F/S GAS
Maytag CRG9830CAB RANGE- S/C F/S GAS
Maytag CRG9830CAE RANGE- S/C F/S GAS
Maytag CRG9830CAM RANGE- S/C F/S GAS
Admiral CRGA250AAL RANGE- F/S STD GAS
Admiral CRGA250AAW RANGE- F/S STD GAS
Admiral CRGA250BAL RANGE- F/S STD GAS
Admiral CRGA250BAW RANGE- F/S STD GAS
Admiral CRGA300AAL RANGE- F/S STD GAS
Admiral CRGA300AAW RANGE- F/S STD GAS
Admiral CRGA300BAL RANGE- F/S STD GAS
Admiral CRGA300BAW RANGE- F/S STD GAS
Admiral CRGA350AAL RANGE- F/S STD GAS
Admiral CRGA350AAW RANGE- F/S STD GAS
Admiral CRGA400AAL RANGE- F/S STD GAS
Admiral CRGA400AAW RANGE- F/S STD GAS
Admiral CRGA400BAL RANGE- F/S STD GAS
Admiral CRGA400BAW RANGE- F/S STD GAS
Admiral CRGA500AAL RANGE- F/S STD GAS
Admiral CRGA500AAW RANGE- F/S STD GAS
Admiral CRGA600AAL RANGE- S/C F/S GAS
Admiral CRGA600AAW RANGE- S/C F/S GAS
Admiral CRGA650AAL RANGE- S/C F/S GAS
Admiral CRGA650AAW RANGE- S/C F/S GAS
Admiral CRGA700AAL RANGE- S/C F/S GAS
Admiral CRGA700AAW RANGE- S/C F/S GAS
Admiral CRGA800AAE RANGE- F/S STD GAS
Admiral CRGA800AAL RANGE- F/S STD GAS
Admiral CRGA800AAW RANGE- F/S STD GAS
Frigidaire CRGF342AS0 Dryer - Frigidaire/best Buy
Frigidaire CRGF342AS1 Dryer - Frig/best Buy
Frigidaire CRGF342AS2 Frigidaire/gas Range
Frigidaire CRGF342AS3 Frigidaire/gas Dryer
Frigidaire CRGF342AS4 Frigidaire/dryer
Frigidaire CRGR442AS0 Dryer - Frig/best Buy
Frigidaire CRGR442AS1 Dryer - Frig/best Buy
Frigidaire CRGR442AS2 Dryer - Frig/best Buy
Frigidaire CRGR5700AS0 Dryer - Frig/best Buy
Frigidaire CRGR5700AS1 Frigidaire/gas Dryer
Frigidaire CRGR5700AS2 Frigidaire/gas Dryer
Frigidaire CRGR5700AS3 Frigidaire/dryer
Frigidaire CRGR7900AS0 Dryer - Frig/best Buy
Frigidaire CRGR7900AS1 Frigidaire/gas Dryer
Frigidaire CRGR7900AS2 Frigidaire/gas Dryer
Frigidaire CRGR7900AS3 Frigidaire/dryer
Amana CRH4-1 COMMERCIAL MICROWAVES
Amana CRH4-3 COMMERCIAL MICROWAVES
Amana CRH5-1 COMMERCIAL MICROWAVES
Amana CRH5-3 COMMERCIAL MICROWAVES
Admiral CRL5300BXA RANGE- F/S STD GAS
Admiral CRL5300BXW RANGE- F/S STD GAS
Admiral CRL5300CXL RANGE- F/S STD GAS
Admiral CRL5300CXW RANGE- F/S STD GAS
Admiral CRL5300DXL RANGE- F/S STD GAS
Admiral CRL5300DXT RANGE- F/S STD GAS
Admiral CRL5300DXW RANGE- F/S STD GAS
Admiral CRL7400CAL RANGE- F/S STD GAS
Admiral CRL7400CAW RANGE- F/S STD GAS
Amana CRMC-20B MWAVE - FAMILY SIZE (60 HZ)
Amana CRMC-30 RANGE- S/C S/I DDRAFT GAS
Amana CRMC-30 MICROWAVE - CONVECTION
Amana CRMC-30 MWAVE - FAMILY SIZE (60 HZ)
Amana CRMC720 MICROWAVE - CONVECTION
Maytag CRP200 RANGE- F/S STD GAS
Maytag CRP200B RANGE- F/S STD GAS
Maytag CRP205 RANGE- F/S STD GAS
Maytag CRP300 RANGE- F/S STD GAS
Maytag CRP300B RANGE- F/S STD GAS
Maytag CRP382 RANGE- F/S STD GAS
Maytag CRP382B RANGE- F/S STD GAS
Maytag CRP5300AXL RANGE- F/S STD GAS
Maytag CRP5300AXW RANGE- F/S STD GAS
Admiral CRPA200AXL RANGE- F/S STD GAS
Admiral CRPA200AXW RANGE- F/S STD GAS
Admiral CRPA200BXL RANGE- F/S STD GAS
Admiral CRPA200BXW RANGE- F/S STD GAS
Amana CRR-1225 MWAVE- CNTRTP / STAND ALONE
Amana CRR-5B MWAVE- CNTRTP / STAND ALONE
Amana CRR-7B MWAVE - FAMILY SIZE (60 HZ)
Amana CRR-9TB MWAVE - FAMILY SIZE (60 HZ)
Amana CRR1220 MWAVE- CNTRTP / STAND ALONE
Amana CRRL-5C MWAVE- CNTRTP / STAND ALONE
Amana CRRL-5C MWAVE - FAMILY SIZE (60 HZ)
Amana CRRL-5D MWAVE- CNTRTP / STAND ALONE
Amana CRRL-5D MWAVE - FAMILY SIZE (60 HZ)
Amana CRRL-700 MWAVE- CNTRTP / STAND ALONE
Amana CRRL-700 RANGE- S/C S/I DDRAFT GAS
Amana CRRL-8TD MWAVE - FAMILY SIZE (60 HZ)
Amana CRRL-8TD MWAVE- CNTRTP / STAND ALONE
Amana CRRL-8X MWAVE- CNTRTP / STAND ALONE
Amana CRRL-8XA MWAVE- CNTRTP / STAND ALONE
Amana CRRL-9TB MWAVE - FAMILY SIZE (60 HZ)
Amana CRRL-9TC MWAVE- CNTRTP / STAND ALONE
Amana CRRL1020 MWAVE- CNTRTP / STAND ALONE
Amana CRRL920 MWAVE- CNTRTP / STAND ALONE
Amana CRS30 MWAVE- CNTRTP / STAND ALONE
  #2 (permalink)
Old 03-23-2011, 03:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove sealed burners:
a) Remove grates
b) Turn each burner CCW about 2 inches to loosen.
c) Once loose, lift the burner straight up and out of the mounting hole.
d) Label and disconnect wire terminals from burner. Remove screw and washer (securing burner support to main top) from the burner openings.
Remove the main top:
a) Raise the front edge of the maintop and pull forward.
b) Lift maintop assembly from the oven chassis.
Now you can remove the side panel.
- The door hinge kit Part number: AP4012074
Here are the breakdown diagrams and Replacement parts for MAYTAG CRG9700BAL RANGE- S/C F/S GAS | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Door Hinge Replacement of maytag Range jtclark45 Oven Repair (including Ranges and Cooktops) 0 10-26-2010 09:23 AM
Door hinge replacement dfelicia Dishwasher Repair 0 08-23-2010 04:07 PM
GE Profile Standalone Gas Range HINGE replacement! hil357 Oven Repair (including Ranges and Cooktops) 0 08-15-2010 05:10 PM
door hinge replacement deny_kasa Oven Repair (including Ranges and Cooktops) 0 06-29-2010 02:05 PM
Oven Door Hinge Replacement Carl L Oven Repair (including Ranges and Cooktops) 0 05-29-2010 06:26 AM
