Discuss
Oven will not bake broil or clean
 in
I moved into a house with CT130 electric ovens. Onw works fine the other is anemic. When I put it
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven will not bake broil or clean
  #1 (permalink)
Old 10-24-2007, 06:32 PM
feinerl feinerl is offline
Junior Member
feinerl is on a distinguished road
Default Oven will not bake broil or clean
Model Number: ct130   Brand: Thermador   Age: 5 - 10 years
I moved into a house with CT130 electric ovens. Onw works fine the other is anemic. When I put it on bake the lower element gets warm but does not become red hot like the other. The same thing happens in broil. The element gets warm but not red hot. The vent on the bottom of the unit was bent and I was getting the E6 error code so I changes the selctor switch and unblocked the exhaust vent. The e6 code no longer comes up but the oven is still not baking or broiling properly. It seems like the full voltage is not being applied to the coils or the coils are both bad which seems unlikely. Any thoughts on how to proceed with troubleshooting?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-24-2007, 08:08 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi feinerl
The first thing I would check is the air interlock switch which is located on the blower housing. It could not work properly due to the grease built up on the actuator. The new switch is no longer available.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 10-24-2007, 09:02 PM
Junior Member
Default Update-still not working
The air switch is OK. THe volatge to the element is only 110V. Any other thoughts? Could it be the high temp cutout?
  #4 (permalink)
Old 10-24-2007, 09:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes. Most likely the problem is there. I'm not sure if it is resettable or it has to be replaced. If it has a red button in the middle then it is resettable. Just push the button.
__________________
  #5 (permalink)
Old 10-24-2007, 09:44 PM
Junior Member
Default
where would I find it? Do I have to pull out the oven?
  #6 (permalink)
Old 10-24-2007, 10:17 PM
Junior Member
Default
I found it. I had to take out two screws and pull the cabinet out about 2 inches. There I saw the red button on the irhgt side of the unit! I pushed it in and my oven works! The previous owners inadverantly bent the grate that allows air to circulate around the oven and must have tripped the cutout. I will sing the praises of this site and buy all my future parts from your website.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't bake, only broil jae Oven Repair (including Ranges and Cooktops) 6 11-10-2007 10:22 PM
element heats up on broil but not on bake RICO Oven Repair (including Ranges and Cooktops) 1 09-18-2007 08:24 PM
Bake and Broil elements not working Janefield Oven Repair (including Ranges and Cooktops) 0 09-04-2007 03:29 PM
Oven Will Not Bake tony Oven Repair (including Ranges and Cooktops) 6 08-01-2007 06:21 PM
Oven doesnt bake ChrisF Oven Repair (including Ranges and Cooktops) 0 07-26-2007 06:25 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
