One day last week we smelled a strong electrical smell while using the oven (not positive it was coming from the oven though). Couple of days later we were frying fish on the cooktop, turned the oven on 200 to keep food warm. Everything just quit heating...all stovetop burners, the oven, and the broiler as well. The lights come on like it wants to work, and clock works, but no heat. Is this an easy fix, or should I call a service technician? Any suggestions would be appreciated!
you might be losing a line some where you can check if you have a voltage meter. but be careful. sheck the plug if its 120v you might be losing a netural. hope this helps.
