i ordered parts from you, and when they arrived, I find that ---they don't fit!!!
The "probe" in my oven has about 1.5"of 'pigtail' on it, with a little white plastic connector with a female fitting.... The one I got, to replace it, has a pigtail of over 6", and the fitting is male.
The connection on my oven is male, so a male probe will not work!!! Help!!!
This is one problem.... I also got a "clock/timer" from you, and it doesn't look the same, and has different model # and control #'s..... The one on my oven is made in Mexico, the one I received from you, is made in China... :confused:
