My two year old oven won't bake or broil. Everthing else on the touchpad works. I cleaned the ribbons from the touch pad to the h1 control (clock)panel. I replaced the h1 control. The problem still exists. Do the touch pads wear out. What is the next step to diagnose the problem? There are no error codes. Thanks
THIS FORUM IS DEAD!!!!!!! |
