| » Popping noises, oven won't heat enough |
Model Number: MGS5870ADW Brand: Maytag Age: 5 - 10 years
When I set my oven to bake 350 degrees, the temperature starts to rise. According to the display, it goes to about 145 degrees, then I hear the gas light. At about 160 degrees, the gas goes off. A couple of seconds later the oven makes popping noises, seems the gas is lighting and then going out in rapid succession.
The broiler works fine as do the burners. As stated above, it is a Maytag MGS5870ADW. It is a convection oven (this occurs on bake without convection as well as with convection). I purchased the oven in 2001. I had a repairman out to my house for my refrigerator and asked him about my oven. He said it was the ignitor, but had no time to deal with my oven. In looking at the diagrams for the gas parts on your web site and in talking to one of your sales reps, there does not appear to be a separate ignitor for baking as opposed to broiling. I'm confused about this as the ignitor that I can see in my oven only glows when the broiler is on, yet I hear the gas light and can see it burning during the cycling noises I hear when my oven is on bake. I'd greatly appreciate any help you could give me. Thank you in advance! |
Hello
Your oven has two igniters, one for the bake burner (#17 on the gas controls break down diagram) and one for the broil burner (#16 on the gas controls break down diagram). It shows only one igniter (#13 on the gas controls break down diagram) because both igniters are the same. Check if the 120V coming to the bake igniter during the Bake mode. Replace the igniter if there is a proper voltage. - The part number for the new oven igniter AP3455359 The oven igniter (bake and broil) - Here are the break down diagrams for the Maytag range Model MGS5870ADW Good luck. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Just remove the floor from the oven and you'll see it. To get the access to wires pull out the storage drawer on the bottom.
__________________
| Display Modes | |
| Dacor Oven won't heat | devorahbee | Oven Repair (including Ranges and Cooktops) | 1 | 05-24-2008 10:56 PM |
| Oven won't heat | ctlopez | Oven Repair (including Ranges and Cooktops) | 0 | 10-03-2007 09:47 AM |
| Oven doesn't heat up | mistyw | Oven Repair (including Ranges and Cooktops) | 0 | 09-07-2007 10:47 PM |
| Oven won't heat to temp | docjolly | Oven Repair (including Ranges and Cooktops) | 0 | 09-03-2007 09:03 PM |
| Oven won't heat up at all. | acillatem | Oven Repair (including Ranges and Cooktops) | 27 | 07-27-2007 12:32 AM |
