When you look at the Fan Switch for CVE 1400B, it shows the control panel as being rectangular with 4 burner controls, and an elongated oval slot for the fan switch which is part #5. When you look at the replacement switch, it is rectangle with two plates that are sold with it, one for an on light and one without. How are you supposed to make these new plates fit the existing control panel?:confused:
