Bake element won't heat.
Bake element will not heat up. Checked element and it is good. From what I have read it is most likely the control board. However they no longer make the control board. Is there anything else I should check before I run out and buy a new oven? :confused: Thanks in advance for your help.
Replacement parts for FRIGIDAIRE PLEB30S8CCB Frigidaire/wall Oven | AppliancePartsPros.com Here is the wiring diagram http://manuals.frigidaire.com/prodin.../318046208.pdf It does show the clock/timer (Item F20 In Section 1) which is the control board as being available. Does the broil element heat up? If not you may have a power problem or the thermal circuit breaker (Item F119 in Section 2) could be open. Looks like it may be resettable if the red square between the contacts has popped out. |
Yes the broiler element heats up just fine. Guess I came to the right place. Thanks for the help.
My next dumb question is how do I take the darn thing apart to replace the control board? |
This may help but I am not sure if it applies to your unit.
http://frigidaireservicetips.com/pdfs/344_UpdateforElectricFreestandingElectricRanges_Re v.pdf |
Thanks again.
Ordered part Monday afternoon. Arrived Wednesday afternoon. Installed and it worked like a charm. THanks for all of your help. Appliance Pros rocks!:D
| All times are GMT -7. The time now is 11:18 PM. |
