Discuss
magic chef wall oven from 1990
 in
wall oven light work, power to oven works, but no red light to thermostat or the coils don't heat up.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » magic chef wall oven from 1990
  #1 (permalink)
Old 03-19-2011, 07:26 AM
Junior Member
a907898 is on a distinguished road
Default magic chef wall oven from 1990
Model Number: 98A-4CX   Brand: Magic Chef   Age: More than 10 years
wall oven light work, power to oven works, but no red light to thermostat or the coils don't heat up. no heat are there parts for this oven?
Ads By Google
Related Models
Magic Chef 98F-4CLX Walloven - Cont Clean Ele
Magic Chef 98F-4CLX-19 Walloven - Cont Clean Ele
Magic Chef 98F-4CW Walloven - Std Ele
Magic Chef 98F-4CX Walloven - Std Ele
Magic Chef 98FA-4CLX Walloven - Cont Clean Ele
Magic Chef 98FA-4CLX-19 Walloven - Cont Clean Ele
Magic Chef 98FA-4CW Walloven - Std Ele
Magic Chef 98FA-4CX Walloven - Std Ele
Magic Chef 98FN-4CLX Walloven - Cont Clean Ele
Magic Chef 98FN-4CLX-19 Walloven - Cont Clean Ele
Magic Chef 98FN-4CW Walloven - Std Ele
Magic Chef 98FN-4CX Walloven - Std Ele
Frigidaire 99-0828-00-03 Tap(v2) / Chest Freezer
Frigidaire 99-0828-23-00 Tap(v1)
Frigidaire 99-0828-23-01 Tap(v2)
Frigidaire 99-0828-23-02 Tap(v3)
Frigidaire 99-0828-23-03 Tap(v1) / Chest Freezer
Frigidaire 99-1348-00-03 Tap(v1) / Upright Freezer
Frigidaire 99-1648-00-00 Tap(v1) / Chest Freezer
Frigidaire 99-1648-00-01 Tap(v2) / Chest Freezer
Frigidaire 99-1648-00-02 Tap(v1) / Chest Freezer
Frigidaire 99-1648-00-03 Tap(v2) / Chest Freezer
Frigidaire 99-1668-00-03 Tap(v1) / Upright Freezer
Frigidaire 99-2188-00-03 Tap(v1) / Upright Freezer
Frigidaire 99-2388-00-00 Tap(v1) / Chest Freezer
Frigidaire 99-2388-00-01 Tap(v2) / Chest Freezer
Frigidaire 99-2388-00-02 Tap(v1) / Chest Freezer
Amana 991.000 Mwave - Family Size (60 Hz)
Amana 992.000 Range - S/c S/i Ddraft Gas
Amana 993.000 Range - S/c S/i Ddraft Gas
Amana 994.000 Range - S/c S/i Ddraft Gas
Magic Chef 99F-4EXW Walloven - S/c Ele
Magic Chef 99FN-4EVW Walloven - S/c Ele
Amana 9C2MA Room Air Conditioner
Amana 9C3EV Room Air Conditioner
Amana 9C3EW Room Air Conditioner
Amana 9C3HES Room Air Conditioner
Amana 9C3HEV Room Air Conditioner
Amana 9C3HEW Room Air Conditioner
Amana 9C5A Room Air Conditioner
Amana 9C5ES Room Air Conditioner
Whirlpool 9CA2000XMW0
Whirlpool 9CA2781XSN1
Whirlpool 9CA2781XSN2
Whirlpool 9CA2781XSW0
Whirlpool 9CA2781XSW1
Whirlpool 9CFA2000W3
Whirlpool 9CFA2000W4
Whirlpool 9CFA2000W5
Whirlpool 9CFA2000W6
Whirlpool 9CSE3W1
Whirlpool 9ED20TKXDN00
Whirlpool 9ED20TKXDN01
Whirlpool 9ED20TKXDW00
Whirlpool 9ED20TKXDW01
Whirlpool 9ED22DQXDN01
Whirlpool 9ED22DQXDW01
Whirlpool 9ED22PKXDN00
Whirlpool 9ED22PKXDN01
Whirlpool 9ED22PKXDW00
Whirlpool 9ED22PKXDW01
Whirlpool 9EET151JTWL0
Whirlpool 9EET151JTWL1
Whirlpool 9EET151JTWL2
Whirlpool 9EET151JTWR0
Whirlpool 9EET151JTWR1
Whirlpool 9EET151JTWR2
Whirlpool 9EET151PKWR0
Whirlpool 9EET151PKWR1
Whirlpool 9EET151PKWR2
Whirlpool 9ET16NKXDG03
Whirlpool 9ET16NKXDN03
Whirlpool 9ET16NKXDW03
Whirlpool 9ET18NKXFN00
Whirlpool 9ET18NKXFW00
Whirlpool 9ET19DKXEN00
Whirlpool 9ET19DKXEW00
Whirlpool 9ET19DKXFB00
Whirlpool 9ET19DKXFN00
Whirlpool 9ET19DKXFW00
Whirlpool 9KP2670-3
Whirlpool 9KSM150PSBU0 5 Qt. Stand Mixer - Japan
Whirlpool 9KSM150PSER0 5 Qt. Stand Mixer - Japan
Whirlpool 9KSM150PSGR0 5 Qt. Stand Mixer - Japan
Whirlpool 9KSM150PSMC0 5 Qt. Stand Mixer - Japan
Whirlpool 9KSM150PSMY0 5 Qt. Stand Mixer - Japan Artisan - Tilt Head
Whirlpool 9KSM150PSOB0 5 Qt. Stand Mixer - Japan Artisan - Tilt Head
Whirlpool 9KSM150PSPK0 5 Qt. Stand Mixer - Japan
Whirlpool 9KSM150PSWH0 5 Qt. Stand Mixer - Japan
Whirlpool 9KSM90GN1 4 1/2 Qt. Stand Mixer
Amana 9M11TA Room Air Conditioner
Amana 9M12TA Room Air Conditioner
Amana 9M32PAE Room Air Conditioner
Amana 9M32PAEH Room Air Conditioner
Amana 9M32PBE Room Air Conditioner
Amana 9M32PBEH Room Air Conditioner
Amana 9M32PCE Room Air Conditioner
Amana 9P-2SPMK Room Air Conditioner
Amana 9P2MA Room Air Conditioner
Amana 9P2MB Room Air Conditioner
Amana 9P2MC Room Air Conditioner
Amana 9P2MY Room Air Conditioner
Amana 9P2SPML Room Air Conditioner
Amana 9QZ22RC Room Air Conditioner
Amana 9QZ22RC1 Room Air Conditioner
  #2 (permalink)
Old 03-20-2011, 06:53 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Cannot find a listing for the given model number but here are part for a 98FA-4CX. It is probably very close to yours.
Does look like most parts are obsolete.
Replacement parts for MAGIC CHEF 98FA-4CX WALLOVEN- STD ELE | AppliancePartsPros.com
How do you know that "power to oven works"?
Have you measured it with a meter?
The oven light runs off of 120 volts but the elements need the full 240 volts.
Perhaps the oven on light also need2 240 but I cannot confirm this as I cannot find a wiring diagram.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug. You may be hard wired.
L1 to L2 should be 240 volts
If OK
If OK
Be careful as 240 volts is lethal !!!
__________________
  #3 (permalink)
Old 03-22-2011, 06:31 AM
Junior Member
Default magic chef
the wall oven is direct to fuse box. My son touched some wires on the back of analog turn and got zapped.
  #4 (permalink)
Old 03-23-2011, 05:24 AM
Senior Expert
APP Volunteer
Default
You have to actually measure it.
By the sound of it you may want to get a pro in unless you have a couple extra sons.
240 volts is lethal!!!
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Magic Chef Wall Oven won't ignite roller84 Oven Repair (including Ranges and Cooktops) 0 07-08-2010 08:29 AM
Help with my Magic Chef wall oven Joe Garza Oven Repair (including Ranges and Cooktops) 1 01-14-2010 01:57 AM
Help with my Magic Chef wall oven Joe Garza Oven Repair (including Ranges and Cooktops) 0 01-12-2010 02:03 PM
magic chef wall oven trikerdave Oven Repair (including Ranges and Cooktops) 1 04-22-2009 01:14 PM
Magic Chef self-cleaning wall oven Chuck Stemple Oven Repair (including Ranges and Cooktops) 0 04-22-2009 12:52 PM
