I need to replace the ignitor module for my GE stove. It says Harper Wyman Kool-lite model 6540, 120 vac, 60 Hz, 8mA. Do you know where I could find this, or do you know of a replacement one I could buy? Thanks. Will
I have the same spark module in my Viking 4 burner range and would like to find a replacement part. No spark to any of the burners. Ohm meter shows no shorts between igniter and burner. All control wires send the appropriate (120v) line signal to the spark module when the control knob is turned on for each burner. Line, ground and neutral wires all check out as being properly connected.
Looks like OEM part number was PA020013 replaced by PA020041 which is compatible with Y705823. Is Maytag/Amana 71001925 spark module compatible? Anyone know the equivalent AP #
