| » Fridgedaire gas range-oven will not heat up |
Model Number: FGF376CESA Brand: -brand- Age: 5 - 10 years
top burners work
broiler works heat warmer drawer works when I set to pre heat the broiler which is on the inside top of oven lights up there is no glow what so ever to be seen on the bottom heating element when I set to bake at 350 or whatever temp, after a few seconds it clicks and goes back to 100 and does not heat up at all, does not show an error code. could this be a heating element problem or clock timer issue. I was going to order the element seeing as it is not to expensive and go from there but I wanted to ask the experts first, thanks ccjden@hotmail.com Ads By Google Related Models |
Quote:
CC, Based on the description & diagnosis You're correct, start be replacing the glow bar igniter, I'm sure you'll be fine from there. Part number: AP2150412 Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
CC,
Great, Remember, to let us know how things went, and be careful with that new igniter, they're really fragile. Good Luck,
__________________
Well, thanks a lot Joe for the great advice and link to part, installed it without to much difficulty and the oven now heats up to the desired temperature just fine, C.J.D.
p.s.- inspecting the old igniter did not reveal any cracks or breaks, not sure what went wrong with it.. |
Quote:
You did a great job, we're glad your up and going. You won't always find a damaged spot in the visible portion of the igniter, They do get weak, just from age, wear and tear(usage) or the circuit fails inside the white porcelain portion of the assembly. You're quite welcome for the assist, you did the work. We're happy to be off help. Good Luck,
__________________
| Display Modes | |
| oven/range top has no heat | jetswalz | Oven Repair (including Ranges and Cooktops) | 2 | 02-12-2011 10:35 AM |
| Fridgedaire Washer Leaking | gordow | Washer Repair | 5 | 11-16-2009 02:49 PM |
| Fridgedaire dishwash won't drain | dlsharp10 | Dishwasher Repair | 1 | 06-17-2009 06:35 PM |
| Gas Range Oven will not heat | wetheridge | Oven Repair (including Ranges and Cooktops) | 1 | 10-14-2008 07:55 AM |
| Fridgedaire glass top range | Don C | Oven Repair (including Ranges and Cooktops) | 0 | 10-11-2008 07:11 AM |
