Discuss
frigidaire Stove tripping ground fault recepticle
 in
I installed this gas stove 5 years ago with no problems since, my wife sprayed cleaner inside oven and when
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » frigidaire Stove tripping ground fault recepticle
  #1 (permalink)
Old 03-15-2011, 05:16 PM
Junior Member
rangebroken is on a distinguished road
Default frigidaire Stove tripping ground fault recepticle
Model Number: fgf337abf   Brand: Frigidaire   Age: 1 - 5 years
I installed this gas stove 5 years ago with no problems since, my wife sprayed cleaner inside oven and when we turn on the stove it trips the ground fault recepticle. Reset it the range and clock work fine, as soon as you turn the oven on it trips! If you suggest it is the electronic oven control what could cause the short? It doesn't look like there are many parts on that circuit board.
Related Models
Frigidaire FGF337ABF Frigidaire/gas Range
Frigidaire FGF337ABH Frigidaire/gas Range
Frigidaire FGF337ABJ Frigidaire/gas Range
Frigidaire FGF337ABL Frigidaire/range
Frigidaire FGF337ASA Frigidaire/gas Range
Frigidaire FGF337ASB Frigidaire/gas Range
Frigidaire FGF337ASC Frigidaire/gas Range
Frigidaire FGF337ASD Frigidaire/gas Range
Frigidaire FGF337ASE Frigidaire/gas Range
Frigidaire FGF337ASF Frigidaire/gas Range
Frigidaire FGF337ASH Frigidaire/gas Range
Frigidaire FGF337ASJ Frigidaire/gas Range
Frigidaire FGF337ASL Frigidaire/range
Frigidaire FGF337AUA Frigidaire/gas Range
Frigidaire FGF337AUC Frigidaire/gas Range
Frigidaire FGF337AUD Frigidaire/gas Range
Frigidaire FGF337AUE Frigidaire/gas Range
Frigidaire FGF337AUF Frigidaire/gas Range
Frigidaire FGF337AUH Frigidaire/gas Range
Frigidaire FGF337AUJ Frigidaire/gas Range
Frigidaire FGF337AUL Frigidaire/range
Frigidaire FGF337AWA Frigidaire/gas Range
Frigidaire FGF337AWC Frigidaire/gas Range
Frigidaire FGF337AWD Frigidaire/gas Range
Frigidaire FGF337AWE Frigidaire/gas Range
Frigidaire FGF337AWF Frigidaire/gas Range
Frigidaire FGF337AWH Frigidaire/gas Range
Frigidaire FGF337AWJ Frigidaire/gas Range
Frigidaire FGF337AWL Frigidaire/range
Frigidaire FGF337BCA Frigidaire/gas Range
Frigidaire FGF337BCB Frigidaire/gas Range
Frigidaire FGF337BCC Frigidaire/gas Range
Frigidaire FGF337BCD Frigidaire/gas Range
Frigidaire FGF337BCE Frigidaire/gas Range
Frigidaire FGF337BCF Frigidaire/gas Range
Frigidaire FGF337BCG Frigidaire/range
Frigidaire FGF337BCH Frigidaire/range
Frigidaire FGF337BCL Frigidaire/range
Frigidaire FGF337EBA Frigidaire/gas Range
Frigidaire FGF337EBC Frigidaire/gas Range
Frigidaire FGF337EBD Frigidaire/range
Frigidaire FGF337ECA Frigidaire/gas Range
Frigidaire FGF337ECC Frigidaire/gas Range
Frigidaire FGF337ECD Frigidaire/range
Frigidaire FGF337ESA Frigidaire/gas Range
Frigidaire FGF337ESC Frigidaire/gas Range
Frigidaire FGF337ESD Frigidaire/range
Frigidaire FGF337EUA Frigidaire/gas Range
Frigidaire FGF337EUC Frigidaire/gas Range
Frigidaire FGF337EUD Frigidaire/range
Frigidaire FGF337EWA Frigidaire/gas Range
Frigidaire FGF337EWC Frigidaire/gas Range
Frigidaire FGF337EWD Frigidaire/range
Frigidaire FGF337GBA Frigidaire/range
Frigidaire FGF337GBB GAS RANGE
Frigidaire FGF337GBC GAS RANGE
Frigidaire FGF337GBD GAS RANGE
Frigidaire FGF337GBE GAS RANGE
Frigidaire FGF337GBF GAS RANGE
Frigidaire FGF337GBG GAS RANGE
Frigidaire FGF337GCA Frigidaire/range
Frigidaire FGF337GCB GAS RANGE
Frigidaire FGF337GCC GAS RANGE
Frigidaire FGF337GCD GAS RANGE
Frigidaire FGF337GCE GAS RANGE
Frigidaire FGF337GCF GAS RANGE
Frigidaire FGF337GCG GAS RANGE
Frigidaire FGF337GCH GAS RANGE
Frigidaire FGF337GCJ GAS RANGE
Frigidaire FGF337GCK GAS RANGE
Frigidaire FGF337GSA Frigidaire/range
Frigidaire FGF337GSB GAS RANGE
Frigidaire FGF337GSC GAS RANGE
Frigidaire FGF337GSD GAS RANGE
Frigidaire FGF337GSE GAS RANGE
Frigidaire FGF337GSF GAS RANGE
Frigidaire FGF337GSG GAS RANGE
Frigidaire FGF337GUA Frigidaire/range
Frigidaire FGF337GUB GAS RANGE
Frigidaire FGF337GUC GAS RANGE
Frigidaire FGF337GUD GAS RANGE
Frigidaire FGF337GUE GAS RANGE
Frigidaire FGF337GUF GAS RANGE
Frigidaire FGF337GWA Frigidaire/range
Frigidaire FGF337GWB GAS RANGE
Frigidaire FGF337GWC GAS RANGE
Frigidaire FGF337GWD GAS RANGE
Frigidaire FGF337GWE GAS RANGE
Frigidaire FGF337GWF GAS RANGE
Frigidaire FGF343BADA Frg(v2) / Gas Range
Frigidaire FGF343BADB Frg(v3) / Gas Range
Frigidaire FGF343BAWA Frg(v1) / Gas Range
Frigidaire FGF343BAWB Frg(v4) / Gas Range
Frigidaire FGF345BHWA Frg(v4) / Gas Range
Frigidaire FGF345BHWB Frigidaire/gas Range
Frigidaire FGF345BHWC Frigidaire/gas Range
Frigidaire FGF345GSA GAS RANGE
Frigidaire FGF345GSB GAS RANGE
Frigidaire FGF345GSC GAS RANGE
Frigidaire FGF345GSD GAS RANGE
Frigidaire FGF348KBA GAS RANGE
Frigidaire FGF348KBB GAS RANGE
Frigidaire FGF348KCA GAS RANGE
Frigidaire FGF348KCB GAS RANGE
Frigidaire FGF348KCC GAS RANGE
Frigidaire FGF348KCD GAS RANGE
Frigidaire FGF348KCE GAS RANGE
Frigidaire FGF348KCF GAS RANGE
Frigidaire FGF348KCG GAS RANGE
Frigidaire FGF348KCH GAS RANGE
Frigidaire FGF348KCJ GAS RANGE
Frigidaire FGF348KCK GAS RANGE
Frigidaire FGF348KMA GAS RANGE
Frigidaire FGF348KMB GAS RANGE
Frigidaire FGF348KSA GAS RANGE
Frigidaire FGF348KSB GAS RANGE
Frigidaire FGF348KSC GAS RANGE
Frigidaire FGF348KSD GAS RANGE
Frigidaire FGF348KSE GAS RANGE
Frigidaire FGF348KSF GAS RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
cooktop shorting out ground fault breaker meltile Oven Repair (including Ranges and Cooktops) 1 11-30-2010 04:37 PM
a/c ground fault trips when compressor starts markmorin2 Heating, Ventilation, and Air Conditioning (HVAC) 0 08-04-2010 06:21 PM
Frigidaire dryer 3-4 prong plug. No ground??? pirate Dryer Repair 9 02-10-2010 06:01 PM
whirlpool stove tripping breaker sanfransteve Oven Repair (including Ranges and Cooktops) 1 05-04-2009 04:53 PM
Ground Fault DCHAR Dishwasher Repair 2 08-07-2007 06:45 AM
