Discuss
Frigidaire range troubles
 in
Well my frigidaire range has let me down again. Last week I used the self clean option on the oven.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Frigidaire range troubles
  #1 (permalink)
Old 12-30-2008, 04:35 PM
Junior Member
Dougj is on a distinguished road
Default Frigidaire range troubles
Model Number: PGLEF385CB2   Brand: Frigidaire   Age: 1 - 5 years
Last week I used the self clean option on the oven. That function worked fine and finished and cooled down normally . However, after that, the door would not open. The door lock that engages when the self cleaning option is in use had not disengaged after the clean was complete.
I was able to get a screwdriver in thru the front and move the door lock mechanism to finally get the door open. However, since then the oven does not seem to heat up properly. If I turn it nto say 375C it only heats to about 175C, while 400C only goes to about 180C, etc
I am suspecting its the oven controll unit, but its $300 and I own it once I buy it whether its the problem or not. So I want to make sure I am on the right track
Any suggestions or information would be appreciated.
Thanks....D.
Ads By Google
Related Models
Frigidaire PGLEF385CB4 Frigidaire Canada/electric Range
Frigidaire PGLEF385CQ4 Frigidaire Canada/electric Range
Frigidaire PGLEF385CS4 Frigidaire Canada/electric Range
Frigidaire PGLEF385EB1 Frigidaire Canada/electric Range
Frigidaire PGLEF385EB2 Frigidaire Canada/electric Range
Frigidaire PGLEF385EB3 Frigidaire/range
Frigidaire PGLEF385EB4 Frigidaire Canada/electric Range
Frigidaire PGLEF385EC1 Frigidaire Canada/electric Range
Frigidaire PGLEF385EC3 Frigidaire/range
Frigidaire PGLEF385EC4 Frigidaire Canada/electric Range
Frigidaire PGLEF385EQ1 Frigidaire Canada/electric Range
Frigidaire PGLEF385ES1 Frigidaire Canada/electric Range
Frigidaire PGLEF385ES2 Frigidaire Canada/electric Range
Frigidaire PGLEF385ES3 Frigidaire/range
Frigidaire PGLEF385ES4 Frigidaire Canada/electric Range
Frigidaire PGLEF387CS4 Frigidaire/electric Range
Frigidaire PGLEF387CS5 Frigidaire/electric Range
Frigidaire PGLEF388CS4 Frigidaire/electric Range
Frigidaire PGLEF388CS5 Frigidaire/electric Range
Frigidaire PGLEF388ES1 Frigidaire/electric Range
Frigidaire PGLEF388ES2 Frigidaire Canada/electric Range
Frigidaire PGLEF388ES3 Frigidaire Canada/electric Range
Frigidaire PGLEF388ES4 Frigidaire/range
Frigidaire PGLEF388ES5 Frigidaire Canada/electric Range
Amana PGO-151 Range - S/c S/i Ddraft Gas
Amana PGO191 Surface Unit - Gas
Frigidaire PGP332LD3 Wwh(v1) / Gas Cooktop
Frigidaire PGP332LW3 Wwh(v2) / Gas Cooktop
Thermador PGR364GDZS
Thermador PGR364GLZS
Thermador PGR366ZS
Maytag PGR4100BDW Range - F/s Std Gas
Maytag PGR4102CDH Range - F/s Std Gas
Maytag PGR4102CDT Range - F/s Std Gas
Maytag PGR4202BDH Range - F/s Std Gas
Maytag PGR4202BDT Range - F/s Std Gas
Maytag PGR4305CDH Range - F/s Std Gas
Maytag PGR4305CDT Range - F/s Std Gas
Maytag PGR4310CDQ Range - F/s Std Gas
Maytag PGR4310CDW Range - F/s Std Gas
Maytag PGR4405CDH Range - F/s Std Gas
Maytag PGR4405CDS Range - F/s Std Gas
Maytag PGR4405CDT Range - F/s Std Gas
Maytag PGR4409ADH Range - F/s Std Gas
Maytag PGR4410ADQ Range - F/s Std Gas
Maytag PGR4410ADW Range - F/s Std Gas
Maytag PGR4410BDQ Range - F/s Std Gas
Maytag PGR4410BDW Range - F/s Std Gas
Maytag PGR4410CDQ Range - F/s Std Gas
Maytag PGR4410CDW Range - F/s Std Gas
Maytag PGR4420LDQ Range - F/s Std Gas
Maytag PGR4420LDW Range - F/s Std Gas
Maytag PGR5702BDH Range - F/s Std Gas
Maytag PGR5702BDT Range - F/s Std Gas
Maytag PGR5705BDH Range - S/c F/s Gas
Maytag PGR5705BDT Range - S/c F/s Gas
Maytag PGR5710BDC Range - S/c F/s Gas
Maytag PGR5710BDQ Range - S/c F/s Gas
Maytag PGR5710BDW Range - S/c F/s Gas
Maytag PGR5715BDQ Range - S/c F/s Gas
Maytag PGR5715BDW Range - S/c F/s Gas
Maytag PGR5720LDQ Range - S/c F/s Gas
Maytag PGR5720LDW Range - S/c F/s Gas
Maytag PGR5750LDQ Range - S/c F/s Gas
Maytag PGR5750LDS Range - S/c F/s Gas
Maytag PGR5750LDW Range - S/c F/s Gas
Maytag PGS3759BDB Range - S/c S/i Gas
Maytag PGS3759BDS Range - S/c S/i Gas
Maytag PGS3759BDW Range - S/c S/i Gas
General Electric PGS908BEM1BB Gas range
General Electric PGS908CEM1CC Gas range
General Electric PGS908SEM1SS Gas range
General Electric PGS908WEM1WW Gas range
General Electric PGS975BEM1BB Gas range
General Electric PGS975SEM1SS Gas range
General Electric PGS975WEM1WW Gas range
Amana PGT-151UWW Range - S/c S/i Ddraft Gas
Amana PGT-183UWW Range - S/c S/i Ddraft Gas
Amana PGT120UB Surface Unit - Gas
Amana PGT120UW Surface Unit - Gas
Amana PGT130 Surface Unit - Gas
Amana PGT130-UD Range - S/c S/i Ddraft Gas
Amana PGT130-UWW Range - S/c S/i Ddraft Gas
Amana PGT130UB1 Surface Unit - Gas
Amana PGT130UD Surface Unit - Gas
Amana PGT130UWW Surface Unit - Gas
Amana PGT130UWW1 Surface Unit - Gas
Amana PGT136 Surface Unit - Gas
Amana PGT136-UD Range - S/c S/i Ddraft Gas
Amana PGT136-UWW Range - S/c S/i Ddraft Gas
Amana PGT136UB1 Surface Unit - Gas
Amana PGT136UD Surface Unit - Gas
Amana PGT136UWW Surface Unit - Gas
Amana PGT136UWW1 Surface Unit - Gas
Amana PGT153 Surface Unit - Gas
Maytag PGT153  Surface Unit - Gas
Amana PGT153UWW Surface Unit - Gas
Maytag PGT153UWW  Surface Unit - Gas
  #2 (permalink)
Old 01-02-2009, 06:13 AM
Junior Member
Default
any suggestions??
  #3 (permalink)
Old 01-02-2009, 05:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Does the Broil work properly?
Pull the Bake heating element out, remove the wires from the heating element terminals and check it for continuity. Check for 120VAC between this wires.
Post the results.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #4 (permalink)
Old 01-03-2009, 04:17 PM
Junior Member
Default
YES the broil feature does work. The top element comes on and the oven heats to almost 550 C (the temp hown on the front display). It does however take considerably longer than normal to get to that temperature.
I pulled the lower element out and yes I do see a short if I place my multi meter across the two leads, thus telling me I have continuity.
Next I placed my meter across the two leads that had been connected to the element, and turned the oven on. I read 240 v across those two leads.
Doug
  #5 (permalink)
Old 01-03-2009, 11:01 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Did you measure its resistance? Did you check the voltage between each lead and ground?
__________________
  #6 (permalink)
Old 01-04-2009, 02:31 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
With 240 volts to the bake element, it should get cherry red, if not=bad bake element.
__________________
  #7 (permalink)
Old 01-04-2009, 10:29 AM
Junior Member
Default
I am reading the resistance across the element at 17 ohms, and I am reading 120v from each element lead to ground.
Also, the bake element is getting "cherry red".
However when I set the oven to say 400 C, it starts normally and beeps when it should , indicating that it has reached 400 C, but the thermometer I have placed inside only reaches 125 C??
D.
  #8 (permalink)
Old 01-04-2009, 11:00 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In such case the problem is a bad control board.
__________________
  #9 (permalink)
Old 01-04-2009, 07:24 PM
Junior Member
Default
is there any possibility its the temperature probe?
  #10 (permalink)
Old 01-05-2009, 03:13 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
This may help
http://www.applianceaid.com/elecrange.html
Check out Item # 7
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help With Frigidaire Gas Range! rcoffee2 Oven Repair (including Ranges and Cooktops) 0 12-08-2009 03:59 PM
Frigidaire Range madubo8 Oven Repair (including Ranges and Cooktops) 0 01-04-2009 06:08 AM
Frigidaire range JudyD Oven Repair (including Ranges and Cooktops) 1 05-23-2008 02:40 PM
Frigidaire Range Schnidly Oven Repair (including Ranges and Cooktops) 0 05-18-2008 06:26 AM
frigidaire range Ruben Lucero Oven Repair (including Ranges and Cooktops) 3 08-01-2007 03:39 PM
