I have a Jenn-Air oven that is not heating properly. The elements will initially heat up (glow) and then quit. The oven gets warm but not hot. I checked the continuity of the elements and both are fine. Is there a thermostat or sensor that may have gone bad? Is it easy to replace?:(
