Discuss
electronic control control of element relay
 in
replaced electronic control and having same problem. k2 and k1 click and power one side of upper an lower element.
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » electronic control control of element relay
  #1 (permalink)
Old 03-13-2011, 01:28 PM
Junior Member
ptbrownie is on a distinguished road
Question electronic control control of element relay
Model Number: 790.46813991   Brand: Kenmore   Age: 5 - 10 years
replaced electronic control and having same problem. k2 and k1 click and power one side of upper an lower element. the 2 pink wires going to the element relay does not have 9vdc when I check voltage at the control on 2nd pink wire from the bottom has 9vdc to ground nothing between the two pink wires when I turn on the bake. ohm the temp probe @ 200k and get 1.1 auto range .851 Does the temp probe activate the element relay??
Ads By Google
Related Models
Kenmore 790.46813991  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46813993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.468140  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46814993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.468190  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819990  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819992  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46819993  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46832100  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46832101  SEARS/GAS RANGE
Kenmore 790.46832102  SEARS/GAS RANGE
Kenmore 790.46833100  DUAL FUEL RANGE
Kenmore 790.46833101  SEARS/GAS RANGE
Kenmore 790.46833102  SEARS/GAS RANGE
Kenmore 790.46834100  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46834101  SEARS/GAS RANGE
Kenmore 790.46834102  SEARS/GAS RANGE
Kenmore 790.46839100  DUAL FUEL SLIDE-IN RANGE
Kenmore 790.46839101  SEARS/GAS RANGE
Kenmore 790.5  HAIR CLIPPERS
Kenmore 790.60031100  ELECTRIC RANGE
Kenmore 790.60071790  ELECTRIC RANGE
Kenmore 790.60071791  ELECTRIC RANGE
Kenmore 790.60071792  ELECTRIC RANGE
Kenmore 790.60071793  ELECTRIC RANGE
Kenmore 790.60071794  ELECTRIC RANGE
Kenmore 790.60201200  ELECTRIC RANGE
Kenmore 790.60201201  ELECTRIC RANGE
Kenmore 790.60301300  ELECTRIC RANGE
Kenmore 790.61031100  GAS RANGE
Kenmore 790.61071790  GAS RANGE
Kenmore 790.61081890  FREESTANDING GAS RANGE
Kenmore 790.61081891  30" GAS RANGE
Kenmore 790.61081892  30" GAS RANGE
Kenmore 790.61081896  RANGE
Kenmore 790.61130100  ELECTRIC RANGE
Kenmore 790.61130101  ELECTRIC RANGE
Kenmore 790.61131100  ELECTRIC RANGE
Kenmore 790.61131101  ELECTRIC RANGE
Kenmore 790.61201200  GAS RANGE
Kenmore 790.61301300  SEARS/GAS RANGE
Kenmore 790.61750100  ELECTRIC RANGE
Kenmore 790.61750102  ELECTRIC RANGE
Kenmore 790.61750103  ELECTRIC RANGE
Kenmore 790.61750104  ELECTRIC RANGE
Kenmore 790.61751100  ELECTRIC RANGE
Kenmore 790.61751102  ELECTRIC RANGE
Kenmore 790.61751103  ELECTRIC RANGE
Kenmore 790.61751104  ELECTRIC RANGE
Kenmore 790.61752100  ELECTRIC RANGE
Kenmore 790.61752102  ELECTRIC RANGE
Kenmore 790.61752103  ELECTRIC RANGE
Kenmore 790.61752104  ELECTRIC RANGE
Kenmore 790.61754100  ELECTRIC RANGE
Kenmore 790.61754102  ELECTRIC RANGE
Kenmore 790.61754103  ELECTRIC RANGE
Kenmore 790.61754104  ELECTRIC RANGE
Kenmore 790.61759300  ELECTRIC RANGE
Kenmore 790.62090100  ELECTRIC RANGE
Kenmore 790.62090101  ELECTRIC RANGE
Kenmore 790.62090102  SEARS/ELECTRIC RANGE
Kenmore 790.62091100  ELECTRIC RANGE
Kenmore 790.62091101  ELECTRIC RANGE
Kenmore 790.62091102  SEARS/ELECTRIC RANGE
Kenmore 790.64090300  ELECTRIC RANGE
Kenmore 790.71000300  GAS RANGE
Kenmore 790.71001300  GAS RANGE
Kenmore 790.71002100  GAS RANGE
Kenmore 790.71002101  GAS RANGE
Kenmore 790.71004100  GAS RANGE
Kenmore 790.71004101  GAS RANGE
Kenmore 790.71010200  GAS RANGE
Kenmore 790.71011200  GAS RANGE
Kenmore 790.71012300  GAS RANGE
Kenmore 790.71014300  GAS RANGE
Kenmore 790.71030300  GAS RANGE
Kenmore 790.71031300  GAS RANGE
Kenmore 790.71032300  GAS RANGE
Kenmore 790.71042300  SEARS/GAS RANGE
Kenmore 790.71044300  SEARS/GAS RANGE
Kenmore 790.71102001  GAS RANGE
Kenmore 790.71102004  GAS RANGE
Kenmore 790.71105890  GAS RANGE
Kenmore 790.71105891  GAS RANGE
Kenmore 790.71105892  GAS RANGE
Kenmore 790.71105893  GAS RANGE
Kenmore 790.74403990  DUAL FUEL RANGE
Kenmore 790.74403991  DUAL FUEL RANGE
Kenmore 790.74403992  DUAL FUEL RANGE
Kenmore 790.74403993  DUAL FUEL RANGE
Kenmore 790.74403994  DUAL FUEL RANGE
Kenmore 790.74403995  DUAL FUEL RANGE
Kenmore 790.74503990  DUAL FUEL RANGE
Kenmore 790.74503991  DUAL FUEL RANGE
Kenmore 790.75503200  RANGE
Kenmore 790.75503201  RANGE
Kenmore 790.79012100  GAS RANGE
Kenmore 790.79013100  GAS RANGE
Kenmore 790.79014100  GAS RANGE
Kenmore 790.79019100  GAS RANGE
Kenmore 790.79112200  SEARS/GAS RANGE
Kenmore 790.79112201  SEARS/GAS RANGE
Kenmore 790.79112202  SEARS/GAS RANGE
Kenmore 790.79113200  SEARS/GAS RANGE
Kenmore 790.79113201  SEARS/GAS RANGE
Kenmore 790.79113202  SEARS/GAS RANGE
Kenmore 790.79114200  SEARS/GAS RANGE
Kenmore 790.79114201  SEARS/GAS RANGE
Kenmore 790.79114202  SEARS/GAS RANGE
Kenmore 790.79119200  SEARS/GAS RANGE
Kenmore 790.79119201  SEARS/GAS RANGE
Kenmore 790.79119202  SEARS/GAS RANGE
Sears 790.8  OUTDOORS POST & WALL LAMP
Kenmore 790.8  HAIR CLIPPERS
Kenmore 790.90102200  ELECTRIC RANGE
Kenmore 790.90104200  ELECTRIC RANGE
Kenmore 790.91010200  ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electronic Control Panel or Touch Pad Control Issue? maxtout4u@aol.com Dishwasher Repair 0 10-08-2010 11:33 AM
Electronic Control Chris Jordan Dryer Repair 0 06-10-2010 11:59 AM
No Display Troubleshooting: Control Panel Assy or Electronic Clock Control Board hddman Oven Repair (including Ranges and Cooktops) 0 04-26-2010 12:09 PM
Control Panel or Electronic Control - which causes blinking panel lights? MarcLCH Dishwasher Repair 1 02-25-2010 03:25 AM
control relay chatter jsquail Refrigerator & Freezer Repair 2 12-18-2008 06:41 AM
