Our Whrilpool oven worked fine the night before, but in the morning completley dead. Checked breaker ok. No lights on control panel. Are there any hidden fuese to the control panel? Thank you
Most likely the problem is a blown control panel thermal fuse. Before you'll order the new fuse, open the control panel and check it for continuity. The file with the instructions is attached to the reply. - The thermal fuse Part number: AP3110028
Originally Posted by: Gene Most likely the problem is a blown control panel thermal fuse. Before you'll order the new fuse, open the control panel and check it for continuity. The file with the instructions is attached to the reply. - The thermal fuse Part number: AP3110028
Thank you. The fuse looks ok. I measured about 123 volts across the thermal fuse, is that about correct voltage to control panel? Any other items to test is appreciated. Perhaps the control panel needs replacing.
Check for 120 VAC between the two wires coming to the control board: the white wire to the P4-10 and the black wire to the P7-1. If the voltage is correct then the control board itself is bad.
Unfortunately this part has been discontinued by the manufacturer.
Originally Posted by: Gene Check for 120 VAC between the two wires coming to the control board: the white wire to the P4-10 and the black wire to the P7-1. If the voltage is correct then the control board itself is bad.
Gene. Thank you. I rechecked the thermal fuse and it is OL, so it must not be working. I ordered a new fuse from Appliance parts pros today. I'll let you know the results this weekend.
