| » Element Heat not Consistent |
Model Number: FEC30S6ABF Brand: Frigidaire Age: 1 - 5 years
I am experiencing a problem with the right front burner on this cooktop and the left rear burner does not work at all (both large elements). The right front burner heats erratically and has sometimes failed to turn off when the dial is turned to off. However, the small elements work fine. I have seen similiar posts and the most recommended fix was to change out the switch. If you look at the frigidaire factory parts catalog (http://www.warnersstellian.com/files...s6a-ptsman.pdf) the two outer switches are labeled as detail 54(small element) and the two inner switches are labled as detail 54A(large element). However the cooktop dial controls are laid out as follows from the top to bottom on the cooktop. Right Rear small element correct should be detail 54 and is Left Rear large element correct should be detail 54A and is Left Front small element incorrect should be 54 but is 54A Right Front large element incorrect should be 54A but is 54 If this is the case, then the wrong switches were installed from the manufacturer on the left front and right front elements. Can someone verify this other than me? If it doesn't matter, then why are there different part numbers for detail 54 and 54A? I just want to make sure I order and install the switches correctly. Thanks, Ads By Google Related Models |
I would like to give a big thanks to all the help I got on this site. NOT!!!!! I had a legitimate question which I thought was very well explained and did not get one response to my question. I will give those of you who were waiting for a response of my findings. I had elements that would not respond to dial adjustments and would not turn off at times. I replaced all four surface switches and cooktop works as good as new. I can tell you this, the Frigidaire parts catalog is incorrect about the placement of the switches. If you order two small element switches and two large element switches do not follow the installation according to the parts catalog. Verify which ones go to the small elements and which ones go to the large elements according to your dial configuration. If you have questions about where the wires go( new switches are not identical) look at the the id out beside the blades( ex. L2, H2, H1, P and L1) on the old switch and make sure to match the wires to the correct blade designation on the new switch. The blades are in different locations but if you pay attention when removing the old switch you will not have any problems.
| Display Modes | |
| Admiral Gas Dryer not consistent | anwaaruth | Oven Repair (including Ranges and Cooktops) | 0 | 03-02-2011 05:44 PM |
| heat element | m3kpierce | Dryer Repair | 1 | 01-27-2011 10:24 AM |
| Heat element vs. heat assembly? | iiyt | Dryer Repair | 0 | 12-05-2010 07:02 PM |
| Element won't heat up (20ohms on element and 120volts to the element)? | puddlejumper123 | Oven Repair (including Ranges and Cooktops) | 0 | 04-22-2008 07:49 PM |
| upper and lower burners not consistent | artkat | Oven Repair (including Ranges and Cooktops) | 0 | 09-28-2007 02:29 PM |
