Discuss
Oven bake element started sparking and then started burning
 in
I have a Magic Chef MOdel CER3725AAW oven baking element that all of a sudden started sparking and then burned
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Oven bake element started sparking and then started burning
  #1 (permalink)
Old 03-10-2011, 06:58 AM
Junior Member
twtodd60 is on a distinguished road
Cool Oven bake element started sparking and then started burning
Brand: Magic Chef   Age: 1 - 5 years
I have a Magic Chef MOdel CER3725AAW oven baking element that all of a sudden started sparking and then burned about a 5 in section. Is this common? I have already ordered a new one from Parts Pros
  #2 (permalink)
Old 03-12-2011, 05:06 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Is this common?
Yes it is.
The problem is that often this type of failure can also take out the control board due to the voltage spikes with a little luck this will not be the case for you.
When replacing the element be sure to unplug or remove power from the unit.
On most units one side of the element is still live even when the element is shut off.
It is also a good idea to clip something (clothespin etc.) onto the element wires so that they do not disappear into the back of the oven before you can get your new element installed.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Getting started Kymbury Dryer Repair 0 02-27-2011 06:15 PM
heats when first started keystone1411 Dryer Repair 0 02-26-2011 07:50 AM
It started with the Condenser Fan Knutervalve00 Refrigerator & Freezer Repair 2 05-19-2010 05:45 PM
