Over the last couple weeks, food has been randomly burning, and cooking unevenly even with the temp set LOWER than what is necessary.
I believe it's a thermostat problem since the temp seems to fluctuate hot/warm.
Is there a way to test the current thermostat? And I can;t seem to find 'thermostat' on the website. The closest item I can find is AP2023670.
Whats does it sound like is the problem with this oven?
The oven sensor sounds like the problem and the part number mentioned is the correct part.
Nat
