Discuss
kenmore oven does not work cooktop works
 in
cook top works fine but clock and oven controls do not work, therefore cannot use oven. Thought it was a
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » kenmore oven does not work cooktop works
  #1 (permalink)
Old 03-09-2011, 06:38 PM
Junior Member
voles is on a distinguished road
Default kenmore oven does not work cooktop works
Model Number: 790.95748991   Brand: Kenmore   Age: More than 10 years
cook top works fine but clock and oven controls do not work, therefore cannot use oven. Thought it was a bad breaker, changed that out, still the same thing. Can anyone give any insight as to what may be the problem?
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
  #2 (permalink)
Old 03-12-2011, 05:19 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Sounds like the control board may be shot
Part number: AP2125564
When you say the clock does not work, is it totally dead?
Also are the lights on the unit working?
The oven light and the control/clock panel uses 120 volts so there is a possibility that you have lost Neutral from the power supply.
__________________
  #3 (permalink)
Old 03-13-2011, 05:43 PM
Junior Member
Default
the clock control is dead i checked power with a volt meter and have 240 power then checked for 120 on both legs and i do have 120 on both. cook top works fine can it still be the control panel and do i need to get the over lay also with the control panel. thanks for your reply.
  #4 (permalink)
Old 03-14-2011, 03:37 AM
Senior Expert
APP Volunteer
Default
That is what I would replace
Odds are that you will not need it but is probable best to disassemble the panel before ordering just to be sure that it comes off without any damage.
__________________
  #5 (permalink)
Old 04-03-2011, 12:25 PM
Junior Member
jim scinto is on a distinguished road
Default Kennmore Gas oven
I have a Kennmore gas range mod # 79078674400 cook top works fine. display is completely out it started a while back the, clock got very dim then it seemed like the oven kept cycling on and off today everthing is dead on the display the electric warmer drawer works no oven lights. I pulled the control display out Ive got power to the board it appears that their are 2 boards that are connected to each other does that mean I have to replace both and if so how much is this going to cost. Can you help? Thanks Jim
  #6 (permalink)
Old 04-04-2011, 05:07 AM
Senior Expert
APP Volunteer
Default
Jim
Please start your own thread using "Post New Topic" a different unit than the one in the original post will just confuse things.
Also I do not usually answer questions involving gas units.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Cooktop works great, oven acts like it wants to work but won't pg021400 Oven Repair (including Ranges and Cooktops) 0 11-01-2010 09:43 AM
Cooktop works; oven won't jmg Oven Repair (including Ranges and Cooktops) 0 07-04-2009 08:27 AM
Kenmore oven wont bake, but will broil and cooktop works pontiac_78_ta Oven Repair (including Ranges and Cooktops) 1 06-28-2009 02:56 PM
oven does not work, cooktop works djgeorge Oven Repair (including Ranges and Cooktops) 7 02-16-2009 05:27 AM
Whirpool oven will not work, cooktop works fine LRN4569 Oven Repair (including Ranges and Cooktops) 1 11-17-2008 08:29 PM
