Discuss
K5xcq0
 in
Hi I have a jenn air electric stove model s105 and serial no 66008857. My wife loves this stove and
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » K5xcq0
  #1 (permalink)
Old 03-09-2011, 12:30 PM
Junior Member
K5xcq0 is on a distinguished road
Question K5xcq0
Model Number: s105   Brand: Jenn-Air   Age: More than 10 years
Hi I have a jenn air electric stove model s105 and serial no 66008857. My wife loves this stove and doesn't want to replace it. The problem we are having is that on a timed bake the oven is about 50 degrees off on the temperature. I tried it yesterday and at 400 the light on the oven shut off at around 350. I assume that the thermostat is bad in the unit, but before I spend over $150. for another one I have a couple of questions. Is there another sensor that could be causing this problem? also if a thermostat is bad does it die gradually or does it just blow out like a light blub? Thanks so much for your help. I was informed that the temperature could be adjusted on the back of the temperataure knob unfortunately this paticular stove has only an oven knob for the oven control.
Related Models
Jenn-Air S105 RANGE- S/I STD DDRAFT ELE
Jenn-Air S105-C RANGE- S/I STD DDRAFT ELE
Admiral S1050EH-Z RANGE- F/S STD ELE
Admiral S1050EJ-Z RANGE- F/S STD ELE
Hoover S1055
Hoover S1057300
Hoover S1057400
Hoover S1057600 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1057700
Hoover S1057800
Hoover S1059--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1059030 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1059130 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1059600 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1061
Hoover S1063
Admiral S1068H-CZW RANGE- S/C S/I ELE
Admiral S1068J-CHZW RANGE- S/C D/I ELE
General Electric S1070A0WW Washer
General Electric S1070A1WW Washer
General Electric S1070A2WW Washer
General Electric S1070A4WW Washer
General Electric S1070A5WW Washer
Admiral S1070EH-KZ RANGE- F/S STD GAS
Admiral S1070EH-Z RANGE- F/S STD GAS
Admiral S1070EJ-KZ RANGE- F/S STD GAS
Admiral S1070EJ-Z RANGE- F/S STD GAS
Hoover S1071--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1071800 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1073--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1075--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1075033
Hoover S1075060 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1077--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1077060 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Admiral S1078EH-KZ RANGE- F/S STD GAS
Admiral S1078H-KLVW RANGE-F/S CONT CLEAN GAS
Admiral S1078W-KLVW RANGE-F/S CONT CLEAN GAS
Hoover S1079--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1079060 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1083--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1083100 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Admiral S1088H-CKZW RANGE- S/C S/I GAS
Admiral S1088J-TKZW RANGE- S/C S/I GAS
Hoover S1093
Hoover S1095
Jenn-Air S110 RANGE- S/I STD DDRAFT ELE
Hoover S1101---
Hoover S1103--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1105--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1112--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1112050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1114--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1117900 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1117981 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1120--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1120050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1127--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1133--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1135--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1137--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1137980 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1141--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1147--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1147050 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover S1147900 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Admiral S1151L-30 SURFACE UNIT- ELE
Admiral S1151L-36G SURFACE UNIT- ELE
Hoover S1156--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Admiral S1171L-30 SURFACE UNIT- GAS
Admiral S1171L-30K SURFACE UNIT- GAS
Admiral S1171L-36GK SURFACE UNIT- GAS
Admiral S1172L-30K SURFACE UNIT- GAS
Jenn-Air S120 RANGE- S/C S/I DDRAFT ELE
Jenn-Air S120-C RANGE- S/C S/I DDRAFT ELE
Jenn-Air S121 RANGE- S/C S/I DDRAFT ELE
Hoover S1211--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1215--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1221--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1223--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Jenn-Air S125 RANGE- S/C S/I DDRAFT ELE
Jenn-Air S125-C RANGE- S/C S/I DDRAFT ELE
Hoover S1311--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1311020 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1315--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1319--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1323--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1329--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1331--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1335--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1337--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1339--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1347--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1349--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1353--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Jenn-Air S136 RANGE- S/C S/I DDRAFT ELE
Jenn-Air S136-C RANGE- S/C S/I DDRAFT ELE
Hoover S1361---
Jenn-Air S136B RANGE- S/C S/I DDRAFT ELE
Jenn-Air S136B-C Range - S/c S/i Ddraft Ele
Jenn-Air S136W RANGE- S/C S/I DDRAFT ELE
Jenn-Air S136W-C RANGE- S/C S/I DDRAFT ELE
Hoover S1410--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1420--- PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Hoover S1420050 PORT-SLIM STYLE,SUITCASE,POWER,COMPACT
Amana S148CA01 REF - SXS/I&W
Amana S148CA03 REF - SXS/I&W
Amana S148DA01 REF - SXS
Amana S148DA03 REF - SXS
Jenn-Air S156 RANGE- S/C S/I DDRAFT ELE
Jenn-Air S156-C RANGE- S/C S/I DDRAFT ELE
Jenn-Air S156B-C RANGE- S/C S/I DDRAFT ELE
Jenn-Air S156W RANGE- S/C S/I DDRAFT ELE
Jenn-Air S156W-C RANGE- S/C S/I DDRAFT ELE
Jenn-Air S160 RANGE- S/C S/I DDRAFT ELE
Jenn-Air S160-C RANGE- S/C S/I DDRAFT ELE
Jenn-Air S161 RANGE- S/C S/I DDRAFT ELE
Jenn-Air S166 RANGE- S/C S/I DDRAFT ELE
Jenn-Air S166-C RANGE- S/C S/I DDRAFT ELE
Jenn-Air S166B RANGE- S/C S/I DDRAFT ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
