I have a Tappan Range model # TGF657BFD2. The display went out and I can not control the oven. Is my problem in the display and if I replace the display will this solve my problem?? Also when I search for the display with the above model #, the database does not have it, it just has TGF657BFD1 instead. The display for this one (AP2127068) looks identical to the one I have, is this the same part? I can not find a part # on my control module. Thanks
I came up with the same thing you did. The part # is 318010300. Tom
