| » Replacing temp sensor |
Model Number: WW30430P Brand: Jenn-Air Age: 5 - 10 years
I am getting an F2 alarm error on my Jenn Air model # WW30430P. From what I can find out it is either a relay board if it has one (does it?) of the temp sensor is bad. Of course I am hoping it is the sensor (less money) and if so do I have to tear the entire oven apart to replace it or can I just remove the two screws that are holding the probe assembly to the back of the oven and remove and replace the probe. Or as my luck usually runs will it require a more extensive tear down of the oven?
Thanks for any help on this issue Ads By Google Related Models |
Your on track for the sensor, but most of the times you have to pull the oven out to unhook the sensor harness. Try to pull it through the front, but don't pull to hard. I would replace the sensor. The part # is 12001656. Tom
Looks like you know what to do.
I need to replace my Whirlpool GS475LEMS 1 Gas Range oven temp. sensor but cannot locate it or sure of how to remove it. The parts dept. on this site really sucks. Part drawings and numbers but no I.D. list of the parts!!! Waz up wi dat?? Please send your info. to lrcdmc@sbcglobal.net I can't trust any other method. Thanks, Larry |
| Display Modes | |
| GE Oven - F3 after replacing oven temp sensor | robjcici | Oven Repair (including Ranges and Cooktops) | 16 | 01-08-2011 03:38 PM |
| Oven temp sensor | Pcat | Oven Repair (including Ranges and Cooktops) | 0 | 10-24-2009 07:41 AM |
| oven temp sensor | TexMac | Oven Repair (including Ranges and Cooktops) | 2 | 08-13-2009 03:41 PM |
| replacing temp sensor | andy b | Oven Repair (including Ranges and Cooktops) | 0 | 06-09-2009 12:58 PM |
| fault codes still present after replacing temp sensor | skip5813 | Oven Repair (including Ranges and Cooktops) | 0 | 10-01-2007 04:43 PM |
