lovenaz1940
#1 Posted : Tuesday, March 8, 2011 12:01:32 PM(UTC)
lovenaz1940
neither bake or broil elememts heat. control panel appears normal.
magician59
#2 Posted : Tuesday, March 8, 2011 12:15:51 PM(UTC)
magician59
Kind of unusual for both elements to fail at the same time. Pull out the range and test for 220VAC at each element witha bake/broil selected. If you don't measure it there, you probably need to replace the clock.
Part number: AP5176341
lovenaz1940
#3 Posted : Tuesday, March 8, 2011 1:16:16 PM(UTC)
lovenaz1940
no voltage at bk. or brl. terminals. have 246 across L1-L2.
L2 out is also dead.
magician59
#4 Posted : Tuesday, March 8, 2011 1:41:27 PM(UTC)
magician59
Sounds like the clock is the culprit.
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl Today at 7:59:18 AM(UTC)
MGR5755QDW OVEN COOKS WHEN PLUGGED IN (Oven Repair (including Ranges and Cooktops))
by Guest 4/9/2024 8:06:48 AM(UTC)
thermador double wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 4/8/2024 11:57:14 PM(UTC)
Whirlpool Oven - Controls Don't Work (Oven Repair (including Ranges and Cooktops))
by Guest 3/25/2024 10:18:22 AM(UTC)
Multiple failures in Whirlpool oven? (Oven Repair (including Ranges and Cooktops))
by Guest 3/22/2024 6:55:50 AM(UTC)
oven cycle light comes on and goes off when oven is not on (Oven Repair (including Ranges and Cooktops))
by Guest 3/19/2024 7:45:28 AM(UTC)
Kitchen Aid Electric Range Oven YKERS208XS1 (Oven Repair (including Ranges and Cooktops))
by Steph325 3/10/2024 12:00:38 PM(UTC)
1950s ge wall oven (Oven Repair (including Ranges and Cooktops))
by Guest 3/8/2024 6:02:49 PM(UTC)
Viking gas range oven troubleshooting (Oven Repair (including Ranges and Cooktops))
by MK_ 3/3/2024 10:10:13 AM(UTC)
Is it safe? Can I use electric oven again after POP noise and breaker tripped? (Oven Repair (including Ranges and Cooktops))
by Guest 3/2/2024 5:41:59 AM(UTC)
Samsung oven temp low limit not switching back on (Oven Repair (including Ranges and Cooktops))
by amriths 2/25/2024 9:26:15 AM(UTC)
KitchenAid Gar Range - Oven Intermittent Lighting (Oven Repair (including Ranges and Cooktops))
by JDinKTX 2/25/2024 5:05:21 AM(UTC)
Viking propane range #VGCC530-4B, oven/broiler dead, all other features working (Oven Repair (including Ranges and Cooktops))
by Andy Douglass 2/21/2024 2:06:07 PM(UTC)
Viking Wall Oven VGSO 166 Temperature Probe (Oven Repair (including Ranges and Cooktops))
by RRR5678 2/20/2024 4:15:01 PM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
