Hello.
We had a power outage last night for several hours and when power was restored the digital display on my range is dark. The cook top igniter works, but no clock or any other display function. Is there a reset or a fuse that I'm missing?
Thanks, Roger.
You most likely need the clock control. The part # is 8523349.
FYI. I called Whirlpool repair about my problem. The tech on the line suggested that I turn the circuit breaker off to the range and turn it back on. I did this and all is well, the oven works and the clock is set.
That is there answer to everything. Tom
