Discuss
Kenmore Range F10 error
 in
I have a Kenmore range that I was using last night to cook Lasagna. It was cooking at 400 for
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Kenmore Range F10 error
  #1 (permalink)
Old 03-07-2011, 01:17 PM
Junior Member
kaf27033 is on a distinguished road
Default Kenmore Range F10 error
Model Number: 790.96602500   Brand: Kenmore   Age: 1 - 5 years
I have a Kenmore range that I was using last night to cook Lasagna. It was cooking at 400 for about 1 hour 40 minutes. I opened the oven to pull the lid of the pan off. After 5 minutes I returned and the top of the lasagna was burning. After looking in the over I could see the broiler element was on (hence the burning) and then the display showed f10 and I shut it off. Now when I try to turn on oven on to bake it starts heating with the broiler element.
From reading through other post I believe it could be the control panel, but thought I would post and see if there are anything I should try to diagnose the problem further. Thanks.
Ads By Google
Related Models
Kenmore 79015011400 ELECTRIC RANGE
Kenmore 79015011401 ELECTRIC RANGE
Kenmore 79015021400 ELECTRIC RANGE
Kenmore 79015021401 ELECTRIC RANGE
Kenmore 79015031400 ELECTRIC RANGE
Kenmore 79015031401 ELECTRIC RANGE
Kenmore 79015032500 ELECTRIC RANGE
Kenmore 79015051401 GAS RANGE
Kenmore 79030172400 GAS WALLOVEN
Kenmore 79030172401 GAS WALLOVEN
Kenmore 79030179400 GAS WALLOVEN
Kenmore 79030179401 GAS WALLOVEN
Kenmore 79030472400 GAS WALLOVEN
Kenmore 79030472401 GAS WALLOVEN
Kenmore 79030472402 GAS WALLOVEN
Kenmore 79030473400 GAS WALLOVEN
Kenmore 79030473401 GAS WALLOVEN
Kenmore 79030473402 GAS WALLOVEN
Kenmore 79030473403 GAS WALLOVEN
Kenmore 79030474400 GAS WALLOVEN
Kenmore 79030474401 GAS WALLOVEN
Kenmore 79030474402 GAS WALLOVEN
Kenmore 79030479400 GAS WALLOVEN
Kenmore 79030479401 GAS WALLOVEN
Kenmore 79030479402 GAS WALLOVEN
Kenmore 79030503600 GAS COOKTOP
Kenmore 79030503601 GAS COOKTOP
Kenmore 79030522800 WALL OVEN
Kenmore 79030522801 WALL OVEN
Kenmore 79030529800 WALL OVEN
Kenmore 79030529801 WALL OVEN
Kenmore 79030552800 GAS WALLOVEN
Kenmore 79030552802 GAS WALLOVEN
Kenmore 79030553800 GAS WALLOVEN
Kenmore 79030553802 GAS WALLOVEN
Kenmore 79030554800 GAS WALLOVEN
Kenmore 79030554802 GAS WALLOVEN
Kenmore 79030559800 GAS WALLOVEN
Kenmore 79030559802 GAS WALLOVEN
Kenmore 79031003600 GAS COOKTOP
Kenmore 79031013600 GAS COOKTOP
Kenmore 79031023700 SEARS PRO/COOKTOP
Kenmore 79031023701 COOKTOP
Kenmore 79031032800 GAS RANGE
Kenmore 79031032801 GAS RANGE
Kenmore 79031032802 GAS RANGE
Kenmore 79031032804 GAS RANGE
Kenmore 79031033800 GAS RANGE
Kenmore 79031033801 GAS RANGE
Kenmore 79031033802 GAS RANGE
Kenmore 79031033803 GAS RANGE
Kenmore 79031033804 GAS RANGE
Kenmore 79031034800 GAS RANGE
Kenmore 79031034801 GAS RANGE
Kenmore 79031034802 GAS RANGE
Kenmore 79031039800 GAS RANGE
Kenmore 79031039801 GAS RANGE
Kenmore 79031039802 GAS RANGE
Kenmore 79031039804 GAS RANGE
Kenmore 79031042800 GAS RANGE
Kenmore 79031042801 GAS RANGE
Kenmore 79031042802 GAS RANGE
Kenmore 79031042803 GAS RANGE
Kenmore 79031042805 GAS RANGE
Kenmore 79031043800 GAS RANGE
Kenmore 79031043801 GAS RANGE
Kenmore 79031043802 GAS RANGE
Kenmore 79031043803 GAS RANGE
Kenmore 79031043805 GAS RANGE
Kenmore 79031049800 GAS RANGE
Kenmore 79031049801 GAS RANGE
Kenmore 79031049802 GAS RANGE
Kenmore 79031049803 GAS RANGE
Kenmore 79031049805 GAS RANGE
Kenmore 79031053000 GAS RANGE
Kenmore 79031062100 GAS RANGE
Kenmore 79031063100 GAS RANGE
Kenmore 79031069100 GAS RANGE
Kenmore 79031073100 GAS RANGE
Kenmore 79032092400 GAS COOKTOP
Kenmore 79032092401 GAS COOKTOP
Kenmore 79032092402 GAS COOKTOP
Kenmore 79032094400 GAS COOKTOP
Kenmore 79032094401 GAS COOKTOP
Kenmore 79032094402 GAS COOKTOP
Kenmore 79032099400 GAS COOKTOP
Kenmore 79032099401 GAS COOKTOP
Kenmore 79032099402 GAS COOKTOP
Kenmore 79032232400 GAS COOKTOP
Kenmore 79032232401 GAS COOKTOP
Kenmore 79032233400 GAS COOKTOP
Kenmore 79032233401 GAS COOKTOP
Kenmore 79032234400 GAS COOKTOP
Kenmore 79032234401 GAS COOKTOP
Kenmore 79032239400 GAS COOKTOP
Kenmore 79032239401 GAS COOKTOP
Kenmore 79032242400 GAS COOKTOP
Kenmore 79032242401 GAS COOKTOP
Kenmore 79032243400 GAS COOKTOP
Kenmore 79032243401 GAS COOKTOP
Kenmore 79032244400 GAS COOKTOP
Kenmore 79032244401 GAS COOKTOP
Kenmore 79032249400 GAS COOKTOP
Kenmore 79032249401 GAS COOKTOP
Kenmore 79032302000 GAS COOKTOP
Kenmore 79032303000 GAS COOKTOP
Kenmore 79032309000 GAS COOKTOP
Kenmore 79032312000 GAS COOKTOP
Kenmore 79032313000 GAS COOKTOP
Kenmore 79032319000 GAS COOKTOP
Kenmore 79032323000 GAS COOKTOP
Kenmore 79032329000 GAS COOKTOP
Kenmore 79032333000 GAS COOKTOP
Kenmore 79032339000 GAS COOKTOP
Kenmore 79032353000 COOKTOP
Kenmore 79032392400 GAS COOKTOP
Kenmore 79032392401 GAS COOKTOP
Kenmore 79032393700 GAS COOKTOP
Kenmore 79032394400 GAS COOKTOP
Kenmore 79032394401 GAS COOKTOP
  #2 (permalink)
Old 03-08-2011, 12:16 PM
Junior Member
Default
Any thoughts on this? I believe the control board is the problem but am looking for any other thoughts before I spend the money to order it.
  #3 (permalink)
Old 03-08-2011, 03:02 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The "F10" error code means that the control senses runaway temperature. The problem is a shorted relay in the EOC (aka a clock/timer) and the correction is to replace the EOC.
- The EOC Part number: AP4700815
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #4 (permalink)
Old 03-09-2011, 07:27 AM
Junior Member
Default
Thank you for the response. I will get the part ordered.
  #5 (permalink)
Old 03-09-2011, 04:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
__________________
  #6 (permalink)
Old 03-10-2011, 06:38 AM
Junior Member
Default
Well I turned on the oven last night and too my suprise it is now working perfectly. Now the question is, do I replace the part or see if it continues to work. My only concern with replacing the part is that I wont be sure that was the problem. Has anyone seen where this could be a sporatic problem?
  #7 (permalink)
Old 03-11-2011, 07:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the error code you posted did show up once then most likely it will do it again.
If you did order the part from APP then you have up to 45 days to return it. I would keep the part and use the oven as often as possible for this period of time.
P.S. The return policy has been changed in 2011 and now you can return any part within 365 days!
__________________
  #8 (permalink)
Old 03-25-2012, 05:30 PM
Junior Member
Dave No is on a distinguished road
Default Kenmore Range F10 error - Me too
This problem is very similar to the one that has started with my Kenmore range this week, except my model number (and manufacturer) is different. The symtoms are very similar - the range was baking fine and suddenly then the the temperature took off (blackening the dish!), the range started beeping away, and the error code F10 was displayed. I just tried it again today (without food in the the oven) and the very same thing eventually happened.
The range is Sear Kenmore Model 970-698380, Serial VF64956897. Can you please advise part number(s) I need to order? I might need to order?
Thanks for the hepl!
Dave No
Winnipeg, Canada
  #9 (permalink)
Old 03-26-2012, 11:12 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Dave,
In your situation you may want to check the oven temperature probe first. It should read about 1100 Ohms at the room temperature.
If the reading is incorrect, replace the oven temperature probe.
If the reading is correct, replace the EOC.
- The oven temperature probe Part number: AP3963654
- The EOC (aka control board) Part number: AP3965663
P.S. As far as I know APP does not ship parts to Canada. You have to have a valid US address to order parts from APP.
__________________
  #10 (permalink)
Old 09-22-2012, 08:18 PM
Junior Member
fsteddy1 is on a distinguished road
Default Have Problem
I have a kenmore range and i a m getting f10 alarms in the middle of the night for no reason my range was made in 2006 the model number is partly scratched all i can see is 970-60**85, mine cooks fine the alarm goes off when the oven is not in use can you tell me what ut can be.
thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Elite Range Error F501 wonderworker Oven Repair (including Ranges and Cooktops) 2 10-21-2010 01:29 PM
Kenmore Elite Range error code help jayp Oven Repair (including Ranges and Cooktops) 15 07-08-2009 02:27 PM
Kenmore Elite Electric Range F20 Error davco Oven Repair (including Ranges and Cooktops) 1 03-18-2008 06:42 PM
Kenmore Range error code F2-E0 mtfurtney Oven Repair (including Ranges and Cooktops) 1 01-28-2008 10:27 AM
F2 Error Code for Kenmore Range familykg Oven Repair (including Ranges and Cooktops) 1 01-21-2008 12:46 PM
