Grensquell
#1 Posted : Saturday, December 27, 2008 9:13:19 AM(UTC)
Grensquell
Howdy,
I have a jennair slide in that the range works perfectly but the oven will not come on by using the membrane switch.
The switch was replaced 5 years ago. I am assuming it is this switch again. This switch is no longer replaced by Jenn Air and I haven't been able to locate one yet. ( Do you Have One?)
The switch does react when I push the oven control mode buttons but the Timer and cancel buttons works fine.
Any ideas would be appreciated.
How do you pull codes from the control panel?
Thanks,
Grensquell
gne_norris
#2 Posted : Wednesday, July 29, 2009 12:49:27 PM(UTC)
gne_norris
I've had my Jenn-air (Jgs8750adb) for 3 years and have needed to replace the control panel 3 times. I was told that it is caused by heat .... note: control panel is just above the oven door! Now they are telling me that the part is not available and for $278, they will install a replacement stove. I've spent $675 already on repair costs (labor not included in warranty) so now I'll be $950 over what I shelled out when I bought this piece of junk in 2006! My choice is to shell out $278 more or go out and buy a stove for $500 or more. This range should have been recalled.
Grensquell
#3 Posted : Thursday, July 30, 2009 6:36:49 AM(UTC)
Grensquell
gne norris,
I am just waiting to replace the stove with a gas unit, and it won't be a Jenn Air or whoever makes it for them.
Nobody answered my question about pulling codes on htis blog either.
Good Luck!
Membrane Switch Issue (Oven Repair (including Ranges and Cooktops))
by ndmuscutt 8/23/2018 10:07:36 PM(UTC)
Need to replace membrane switch in Kitchenaid Range (Oven Repair (including Ranges and Cooktops))
by kenrmay@sbcglobal.net 11/11/2012 4:36:57 AM(UTC)
Key pad membrane switch or control panel (Oven Repair (including Ranges and Cooktops))
by jmusci 9/11/2012 1:16:55 PM(UTC)
Replaced membrane switch (Oven Repair (including Ranges and Cooktops))
by Beaver81 8/30/2012 12:44:36 PM(UTC)
Replacing Membrane Switch (Microwave Repair)
by shorner 2/9/2011 9:05:55 AM(UTC)
Bad Membrane Switch? (Oven Repair (including Ranges and Cooktops))
by Dean Family 11/27/2009 2:27:04 PM(UTC)
Membrane switch fails on 4 numbers (Oven Repair (including Ranges and Cooktops))
by fred leonard 2/3/2009 7:25:12 AM(UTC)
