| » Kenmore Oven Bottom Burner Will Not Light |
Model Number: 66575775890 Brand: Kenmore Age: 5 - 10 years
My Kenmore oven will not heat to the selected temperature. When the "preheat complete" tone sounds, an oven thermometer demonstrated that the temperature was less than that selected. As a result, I took the bottom cover and the baffle off and observed that while the ignitor turned orange, the burner did not light. A broiler burner on the other hand did light. Does any one why the over burner would not light even when the ignitor turned orange?
Quote:
You most likely have a weak igniter, 98% sure based on your post. Not only does the igniter glow, at the same time it's glowing, it has to produce 3.2 to 3.6 amps, or 3.2 to 3.6 VAC back to the bake burner valve, to open the bi metal switch on the valve and the gas to be released and ignited. If you don't have a amp meter or multi meter to test the circuit, replace the igniter first. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
Quote:
Kfost, Great job, Glad you took the initiative, and figured it out. You'll be up and running in no time. And you did it all. Good Luck,
__________________
| Display Modes | |
| Kenmore Oven Bottom Burner Will Not Light | kfost | Oven Repair (including Ranges and Cooktops) | 0 | 03-06-2011 12:19 PM |
| Oven burner wont light or takes a long time to light | shadyray | Oven Repair (including Ranges and Cooktops) | 4 | 01-30-2011 08:26 PM |
| Replaced bottom oven burner. | joejordan | Oven Repair (including Ranges and Cooktops) | 0 | 04-07-2009 02:58 PM |
| Bottom burner of oven will not heat | angievpark | Oven Repair (including Ranges and Cooktops) | 3 | 12-18-2008 09:21 AM |
| Gas oven-no bottom burner | lwright99@alltel.net | Oven Repair (including Ranges and Cooktops) | 6 | 03-29-2008 11:04 AM |
