| » Oven not heating |
Model Number: ct130 Brand: Thermador Age: 5 - 10 years
I moved into a house that has two units CT130 lectiric oens. One works fine but eh other will not heat up properly. NO error code comes up but it wont get hot. It begins to warm up and a fan comes on. If I try to increase the set temp sometimes it just shuts down. I have done a reset at the breaker to no avail. ANy ideas?
I have had the same oven since new in 1993 and this symptom has occurred several times. Each time I replace the switch and it works for a year or so. After setting the temperature, the "heat" light will not come on. If I kick the panel adjacent to the switch very hard, the light will come on and the oven will heat. However I have injured my knee kicking the oven so have just ordered another switch assembly for the 4th time. The small phosphor-bronze fingers in the rear wafer of the switch assembly appear to lose their tension and make erratic contact with the circuit board, prompting the "Error E6" code. I have tried to repair the board by cleaning and re-tensioning the fingers, but with limited success. Good luck!
--sam bledsoe |
| Display Modes | |
| Oven door opens when in use causing oven to stop heating | puck | Oven Repair (including Ranges and Cooktops) | 3 | 03-14-2009 07:25 AM |
| Bottom heating element in oven not heating | Bill Pitts | Oven Repair (including Ranges and Cooktops) | 1 | 03-07-2009 06:02 PM |
| Oven not heating | jlyon | Oven Repair (including Ranges and Cooktops) | 1 | 02-04-2009 01:00 PM |
| Frigidaire Double Oven/ Top oven not heating | dross3491 | Oven Repair (including Ranges and Cooktops) | 6 | 12-14-2008 12:33 PM |
| GE Wall Double Oven Top Oven Not Heating | ryoung | Oven Repair (including Ranges and Cooktops) | 0 | 01-10-2008 08:02 PM |
