| » GE Double wall oven |
Model Number: JKP26GP3BG Brand: GE Age: More than 10 years
I have a GE Oven (JKP26GP3BG) that is about 17 years old. It does not come up to the temperature that you set it at. For example, set it at 350 degrees and it gets to about 200. The bottom element comes on and will cycle on and off.
I have replaced the temperature sensor and it did not work. I was told by the repair shop to swap the wires and I did so and it still is doing the same thing. No error codes are being displayed. I cut the wires to the sensor and used the wire nuts that came with the part to keep from removing the oven from the wall. Any suggestions? Ads By Google Related Models |
Sounds like a control board (clock) problem.
Unfortunately this is a GE unit so I cannot get any tech info on it. Ge likes to keep everything a secret. This is an old unit so I would feel more confident if I could get tech info. They use a thermostat and a control board and I do not know how they wire the thermostat into the control board. It looks like the control board (clock) is obsolete.
__________________
| Display Modes | |
| Ge Double wall oven | sloka | Refrigerator & Freezer Repair | 3 | 02-19-2011 08:16 PM |
| Double Wall Oven | PSQUARE5 | Oven Repair (including Ranges and Cooktops) | 0 | 12-05-2010 09:04 AM |
| Double Wall Oven | PSQUARE5 | Microwave Repair | 0 | 12-03-2010 02:23 AM |
| GE double wall oven | inspector364 | Oven Repair (including Ranges and Cooktops) | 0 | 10-01-2009 10:18 AM |
| Double Wall Oven | JWhipp | Oven Repair (including Ranges and Cooktops) | 1 | 12-05-2008 08:01 PM |
