Discuss
Tappen oven flames are way to hi
 in
Bought safety valve AP2131109 (3203459). Now when oven ignites flames shoot above the oven bottom about a foot. Gets to
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Tappen oven flames are way to hi
  #1 (permalink)
Old 12-26-2008, 07:45 AM
Junior Member
tedems is on a distinguished road
Unhappy Tappen oven flames are way to hi
Model Number: 30-2249-23/02165-892-51594   Brand: Tappan   Age: More than 10 years
Bought safety valve AP2131109 (3203459). Now when oven ignites flames shoot above the oven bottom about a foot. Gets to 400 degrees in less than a minute. I'm presuming this is not normal. Looking at the old valve and the new . The old valve looks as if it has a smaller orifice than does the new. Did they send me a Nat gas? The old orifice also sits low from the base of the valve than the new. Should i send it back for replacement? what should i do
Ads By Google
Related Models
Frigidaire 30-2249-66-02 Tap(v3) / Gas Range
Frigidaire 30-2249-66-03 Tap(v6) / Gas Range
Frigidaire 30-2251-00-01 Tap(v1) / Gas Range
Frigidaire 30-2251-00-02 Tap(v1) / Gas Range
Frigidaire 30-2251-00-03 Tap(v1) / Gas Range
Frigidaire 30-2251-00-04 Tap(v3) / Gas Range
Frigidaire 30-2251-00-05 Tap(v1) / Gas Range
Frigidaire 30-2251-00-06 Tap(v2) / Gas Range
Frigidaire 30-2251-00-07 Tap(v3) / Gas Range
Frigidaire 30-2251-00-08 Tap(v5) / Gas Range
Frigidaire 30-2251-00-09 Tap(v3) / Gas Range
Frigidaire 30-2251-00-10 Tap(v1) / Gas Range
Frigidaire 30-2251-00-11 Tap(v1) / Gas Range
Frigidaire 30-2251-23-01 Tap(v2) / Gas Range
Frigidaire 30-2251-23-02 Tap(v2) / Gas Range
Frigidaire 30-2251-23-03 Tap(v2) / Gas Range
Frigidaire 30-2251-23-04 Tap(v4) / Gas Range
Frigidaire 30-2251-23-05 Tap(v4) / Gas Range
Frigidaire 30-2251-23-06 Tap(v5) / Gas Range
Frigidaire 30-2251-23-07 Tap(v6) / Gas Range
Frigidaire 30-2251-23-08 Tap(v6) / Gas Range
Frigidaire 30-2251-23-09 Tap(v4) / Gas Range
Frigidaire 30-2251-23-10 Tap(v2) / Gas Range
Frigidaire 30-2251-23-11 Tap(v2) / Gas Range
Frigidaire 30-2252-00-01 Tap(v1) / Gas Range
Frigidaire 30-2252-00-02 Tap(v1) / Gas Range
Frigidaire 30-2252-00-03 Tap(v2) / Gas Range
Frigidaire 30-2262-23-01 Tap(v1) / Gas Range
Frigidaire 30-2262-23-02 Tap(v1) / Gas Range
Frigidaire 30-2272-00-01 Tap(v1) / Gas Range
Frigidaire 30-2272-00-02 Tap(v1) / Gas Range
Frigidaire 30-2272-00-03 Tap(v2) / Gas Range
Frigidaire 30-2272-00-04 Tap(v1) / Gas Range
Frigidaire 30-2272-00-05 Tap(v1) / Gas Range
Frigidaire 30-2272-00-06 Tap(v1) / Gas Range
Frigidaire 30-2272-00/07 Tap(v1) / Gas Range
Frigidaire 30-2272-23-01 Tap(v2) / Gas Range
Frigidaire 30-2272-23-02 Tap(v3) / Gas Range
Frigidaire 30-2272-23-03 Tap(v4) / Gas Range
Frigidaire 30-2272-23-04 Tap(v2) / Gas Range
Frigidaire 30-2272-23-05 Tap(v2) / Gas Range
Frigidaire 30-2272-23-06 Tap(v2) / Gas Range
Frigidaire 30-2272-23/07 Tap(v2) / Gas Range
Frigidaire 30-2518-00-01 Tap(v1) / Gas Range
Frigidaire 30-2518-00-02 Tap(v4) / Gas Range
Frigidaire 30-2518-00-03 Tap(v7) / Gas Range
Frigidaire 30-2518-23-01 Tap(v2) / Gas Range
Frigidaire 30-2518-23-02 Tap(v5) / Gas Range
Frigidaire 30-2518-23-03 Tap(v8) / Gas Range
Frigidaire 30-2518-66-01 Tap(v3) / Gas Range
Frigidaire 30-2518-66-02 Tap(v6) / Gas Range
Frigidaire 30-2518-66-03 Tap(v9) / Gas Range
Frigidaire 30-2528-00-01 Tap(v1) / Gas Range
Frigidaire 30-2528-00-02 Tap(v3) / Gas Range
Frigidaire 30-2528-00-03 Tap(v5) / Gas Range
Frigidaire 30-2528-00-04 Tap(v7) / Gas Range
Frigidaire 30-2528-00-05 Tap(v1) / Gas Range
Frigidaire 30-2528-23-01 Tap(v2) / Gas Range
Frigidaire 30-2528-23-02 Tap(v4) / Gas Range
Frigidaire 30-2528-23-03 Tap(v6) / Gas Range
Frigidaire 30-2528-23-04 Tap(v8) / Gas Range
Frigidaire 30-2528-23-05 Tap(v2) / Gas Range
Frigidaire 30-2537-00-03 Tap(v1) / Gas Range
Frigidaire 30-2537-23-03 Tap(v2) / Gas Range
Frigidaire 30-2537-66-03 Tap(v3) / Gas Range
Frigidaire 30-2538-00-01 Tap(v1) / Gas Range
Frigidaire 30-2538-00-02 Tap(v4) / Gas Range
Frigidaire 30-2538-00-03 Tap(v1) / Gas Range
Frigidaire 30-2538-00-04 Tap(v1) / Gas Range
Frigidaire 30-2538-00-05 Tap(v7) / Gas Range
Frigidaire 30-2538-00-06 Tap(v10) / Gas Range
Frigidaire 30-2538-23-01 Tap(v2) / Gas Range
Frigidaire 30-2538-23-02 Tap(v5) / Gas Range
Frigidaire 30-2538-23-03 Tap(v2) / Gas Range
Frigidaire 30-2538-23-04 Tap(v2) / Gas Range
Frigidaire 30-2538-23-05 Tap(v8) / Gas Range
Frigidaire 30-2538-23-06 Tap(v11) / Gas Range
Frigidaire 30-2538-66-01 Tap(v3) / Gas Range
Frigidaire 30-2538-66-02 Tap(v6) / Gas Range
Frigidaire 30-2538-66-03 Tap(v3) / Gas Range
Frigidaire 30-2538-66-04 Tap(v3) / Gas Range
Frigidaire 30-2538-66-05 Tap(v9) / Gas Range
Frigidaire 30-2538-66-06 Tap(v12) / Gas Range
Frigidaire 30-2542-00-01 Tap(v1) / Gas Range
Frigidaire 30-2542-00-02 Tap(v1) / Gas Range
Frigidaire 30-2542-00-03 Tap(v3) / Gas Range
Frigidaire 30-2542-23-01 Tap(v2) / Gas Range
Frigidaire 30-2542-23-02 Tap(v2) / Gas Range
Frigidaire 30-2542-23-03 Tap(v4) / Gas Range
Frigidaire 30-2549-00-01 Tap(v1) / Gas Range
Frigidaire 30-2549-00-02 Tap(v3) / Gas Range
Frigidaire 30-2549-00-03 Tap(v1) / Gas Range
Frigidaire 30-2549-00-04 Tap(v1) / Gas Range
Frigidaire 30-2549-00-05 Tap(v3) / Gas Range
Frigidaire 30-2549-00-06 Tap(v5) / Gas Range
Frigidaire 30-2549-00-07 Tap(v1) / Gas Range
Frigidaire 30-2549-23-01 Tap(v2) / Gas Range
Frigidaire 30-2549-23-02 Tap(v4) / Gas Range
Frigidaire 30-2549-23-03 Tap(v2) / Gas Range
Frigidaire 30-2549-23-04 Tap(v2) / Gas Range
Frigidaire 30-2549-23-05 Tap(v4) / Gas Range
Frigidaire 30-2549-23-06 Tap(v6) / Gas Range
Frigidaire 30-2549-23-07 Tap(v2) / Gas Range
Frigidaire 30-2551-00-01 Tap(v1) / Gas Range
Frigidaire 30-2551-00-02 Tap(v3) / Gas Range
Frigidaire 30-2551-00-03 Tap(v1) / Gas Range
Frigidaire 30-2551-00-04 Tap(v1) / Gas Range
Frigidaire 30-2551-23-01 Tap(v2) / Gas Range
Frigidaire 30-2551-23-02 Tap(v4) / Gas Range
Frigidaire 30-2551-23-03 Tap(v2) / Gas Range
Frigidaire 30-2551-23-04 Tap(v2) / Gas Range
Frigidaire 30-2552-00-01 Tap(v1) / Gas Range
Frigidaire 30-2552-00-02 Tap(v1) / Gas Range
Frigidaire 30-2552-23-01 Tap(v2) / Gas Range
Frigidaire 30-2552-23-02 Tap(v2) / Gas Range
Frigidaire 30-2757-00-03 Tap(v1) / Gas Range
Frigidaire 30-2757-00-04 Tap(v4) / Gas Range
Frigidaire 30-2757-00-05 Tap(v1) / Gas Range
Frigidaire 30-2757-00-06 Tap(v4) / Gas Range
Frigidaire 30-2757-23-03 Tap(v2) / Gas Range
  #2 (permalink)
Old 12-26-2008, 02:13 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
What kind of gas supply is used for the oven? All parts for gas appliances are sold for natural gas only everywhere in US.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 12-27-2008, 06:04 AM
Junior Member
Default Oven flames too high
Its a LP gas feed. The information on the sticker of the new valve says liquid propane.
  #4 (permalink)
Old 12-27-2008, 01:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by tedems View Post
...The old valve looks as if it has a smaller orifice than does the new. Did they send me a Nat gas?...
A bigger orifice is for natural gas and this is the only way how such parts sold. In case if appliance has to be converted to LP all manufacturers used a conversion kit which usually included a different (smaller) orifices.
The part number for this safety valve does not have any references about LP gas. This is very interesting and I appreciate if you can post this sticker.
P.S. Very likely this range has been converted by someone else.
__________________
  #5 (permalink)
Old 12-27-2008, 03:05 PM
Junior Member
Default Oven temp lames to high
This is a zip file. The "G-LP" info is easily seen.
  #6 (permalink)
Old 12-27-2008, 05:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The sticker on the gas valve says "G-LP .5 P.S.I." which means "1/2 PSI max inline pressure" and nothing else. This is standard for all domestic gas ranges.
__________________
  #7 (permalink)
Old 12-27-2008, 07:01 PM
Junior Member
Default
What do i do with what i've got?
  #8 (permalink)
Old 12-27-2008, 07:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Try to use the orifice from the old valve.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Tappen oven 11-1168/30 mjk3101 Oven Repair (including Ranges and Cooktops) 1 07-11-2009 01:06 PM
tappen oven not working Msoroka24 Oven Repair (including Ranges and Cooktops) 1 03-18-2009 04:33 AM
Tappen Mobil Home wall oven rierie Oven Repair (including Ranges and Cooktops) 1 07-28-2008 08:02 PM
the flames into the oven go on and off victor borcea Oven Repair (including Ranges and Cooktops) 1 04-02-2008 05:36 AM
Tsting a Tappen Oven lower element patrickingalls Oven Repair (including Ranges and Cooktops) 1 01-15-2008 06:34 PM
