Discuss
Lower oven won't turn off
 in
I have a 24" KitchenAid Superba double wall oven with pushbutton electronic controls. Yesterday I had both ovens cooking
Appliance Repair Forum > Appliance Repair Help > Oven Repair (including Ranges and Cooktops) » Lower oven won't turn off
  #1 (permalink)
Old 10-21-2007, 01:47 PM
bthomas202 bthomas202 is offline
Junior Member
bthomas202 is on a distinguished road
Default Lower oven won't turn off
Model Number: KEBS247DWH7   Brand: Kitchen Aid   Age: Less than 1 year
I have a 24" KitchenAid Superba double wall oven with pushbutton electronic controls. Yesterday I had both ovens cooking and turned them both off. The display went black normally, but the lower oven unit didn't turn off. I woke up at 3:00 a.m. and heard the oven fan going. The lower unit was still on. It was still hot. I pressed the off button several times--nothing happened. I finally had to trip the breaker switch to turn the oven off. This morning after the oven had cooled off, I turned the breaker switch back on. I did not touch the controls to turn either over on or off, but the lower oven started heating up again. What's the problem?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 11-23-2007, 06:36 AM
rvb rvb is offline
Junior Member
rvb is on a distinguished road
Default
We have just experienced the exact same thing, except with the upper oven. I was wondering what you did to correct the problem?
  #3 (permalink)
Old 11-23-2007, 07:16 AM
Junior Member
Default
Regrettably, we had to replace the whole oven, and after only 8 years! This might seem stupid, but I replaced it with a Whirlpool oven (essentially the same oven, but without all the fancy gadgets). I did it because it's a 24" wide cabinet, and I was limited as to the vendors who make that narrow a unit.
I called the Whirlpool Company and complained about the old oven. They agreed to extend the manufacturer's warranty on the replacement unit from one to two years. Then, we bought a 5 year service contact through Sears for $200.
The replacement unit cost just under $900, with a 10% rebate from Sears. Of course, there was added cost for installation and the service contract, so I got out for about $1,200 total. But at least I have a new oven. It was going to cost $750 to replace the control module and keypad for the old unit.
The new unit is much quieter than the KitchenAid, and it bakes beautifully.
Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Oven won't turn on jdayseidel Oven Repair (including Ranges and Cooktops) 4 11-21-2007 05:59 PM
Problem with Amana oven it just does not turn on nadmit Oven Repair (including Ranges and Cooktops) 1 10-22-2007 08:51 PM
Electric Double Oven - Lower Locked lfein Oven Repair (including Ranges and Cooktops) 0 09-21-2007 03:24 PM
lower spray arm jiml Dishwasher Repair 1 09-10-2007 09:38 AM
Oven will not turn off daugherr Oven Repair (including Ranges and Cooktops) 0 08-23-2007 05:15 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
